Old 12th October 2005, 12:31 PM   #1 (permalink)
Do you HAVE to drain the gearbox oil when changing the clutch?
I`ve bought some redline heavy shockproof to try but I will also be fitting a clutch in maybe a month or 2.
Should I wait and do the clutch before filling the gearbox with £100 worth of oil? Can you change the clutch without draining the box? (or loosing much of it anyway)
Cheers...
Old 12th October 2005, 12:50 PM   #2 (permalink)
Pikey's Avatar
Why would you need to drain the gearbox oil to change the clutch?
Old 12th October 2005, 01:27 PM   #3 (permalink)
Silver R33 GTR's Avatar
Like already said, you shouldn't really need to change the oil or lose and.
When i changed mine i only lost a little out of the gear turret because it was only two of us lifting it out and that g/box is a heavy bugger.
if you have a ramps and a transmission jack then you shouldnt lose any.
robin
Silver R33 GTR is offline   Reply With Quote
Old 12th October 2005, 01:54 PM   #4 (permalink)
Pikey - Its a UK car with cooler pipes attached. These might need removing to move the gearbox? Other than that, just spillage out of the driveshaft / propshaft holes.
Sounds like it would be OK to refill now.
Thanks.
Old 12th October 2005, 03:39 PM   #5 (permalink)
paul cawson's Avatar
My gearbox fell off the jack a lot of the oil ran out of the gear stick plate hole all over the garage floor. Drain it in a clean container then put it back for what little time it takes.Dont re fill the gearbox from the gear stick hole though most of it stays in the transfer box and sprays out as you drive
Old 12th October 2005, 04:39 PM   #6 (permalink)
Pikey's Avatar
lol
Have you tried having the car towed with no gearstick installed? Above about 20mph you get a little fountain effect
Old 12th October 2005, 05:25 PM   #7 (permalink)
Originally Posted by Pikey
lol
At 70mph with 5litres of oil in the transfer box you get the James Bond effect.
Old 13th October 2005, 08:00 AM   #8 (permalink)
That was fun, in the pi****ng rain, with a siezed filler plug. DoH, DoH, DoH!
Old 17th October 2005, 11:05 PM   #9 (permalink)
And were you not tempted to just pour it in through the gear stick hole
