#4 (permalink) | |
Banned
are they a straight swap then?? where can i get the full gasket set from? |
Full gasket set from Nissan is about £80. That includes all copper washers, all metal gaskets and all fabric gaskets for the turbo inlet pipes, all copper washers but does NOT include exhaust manifold gaskets - they're another £30 for HKS ones
hi while on the subject the 34 tubs have a v small oil feed hole, about 0.5 mm & the normal ones are about 2.5 to 3mm so do,s the 34 or 34 N1,s run a small filt or gorz in the oil feed coss this hole can block v easy
#9 (permalink) | |
guess that wont help if you get a blow and have to do the job again. |
