R32 GTR
I am possibly considering the sale of my 32gtr to fund a new project, and would like to gauge interest, this is a list of the cars current specification.
Engine has covered approx 2000 miles, car has covered 52,000km plus 8,000miles. Trust T88 34d turbo kit Hks 86mm Forged pistons Shot peened lightened/balanced con rods Balanced crankshaft N1 block N1 oil pump N1 water pump Copper/brass radiator Nismo rad cap Tomei sump baffle Acl bearings Tomei Metal gasket 1.6mm* Tomei oil gallery restricter Apexi triple Plate clutch* Sard 800cc Dual pintle inj* HKS Step 1 cams* Hks cam pullies Iridium spark plugs Hks racing type 2 blow off valve Tomei Reytec airflow less drag ecu* Nismo timing belt Trust clear timing cover R33 gtr wheels 255-40-17 tyres x4* 3x Uprated 255ltr fuel pumps Nitrous kit -Direct port 75hp* Nitrous bottle heater Greddy Ex temp gauge* Trust profec a boost controller HKS Glove box insert Jic negative camber front top arms OS Giken gear kit* Nismo solid shift lever Strut brace Engine brace Cusco oil catch tank Hi flow exhaust system Decat pipe Hks intercooler Type R HKS Air filters Braided fuel lines (PTFE lined) Aeromotive Fuel regulator Sard Fuel Surge tank HKS Fuel rail Alloy gearbox mounts Custom 1 pce propshaft Alloy rear axle mounts Nismo rear axle bushes Cusco Adjustable rear camber arms Hicas cancel kit Hicas/aircon removed Project mu brake discs Bilstein dampers Carbon bonnet Carbon Boot lid Jun front bumper Hid headlight conversion Hks Kansai attessa active 4wd controller The car runs 10's in full trim on street tyres and 95 octane. |
Tomei head gasket is 1.5mm not 1.6mm as specified in the original post.
Nismo thermostat fitted. Samco silicone Rad hoses. Samco silicone boost hoses. Last edited by G-sport; 25th October 2005 at 08:29 PM. |
