Power FC Pro launch control - how???
I'll apologise if people view this as a spurious extra thread, but the other two aren't specifically about the launch control feature on the Power FC Pro.
I got my PFC Pro second hand with no instruction manual, and having had a brief flcik through the SETTINGS and ETC. menu cannot, for the life of me, see how to access this function. There are a few things on there that I'm not sure what they are, but I don't want to go playing in screwing it all up. Can someone please explain, clearly and in idiot-proof language ![]() - how to access and set up the launch control function?Cheers for any help anyone can offer Jim |
On the Rev limit page the top figure is the standard limiter figure (i.e 7000rpm etc), the NEXT figure down is the L/C rev limit. Set it to 3000rpm (for a test) and exit the setting menu.
Then, with the car stationary (it only activates at 0mph, then turns off at 1mph+) blip the throttle past 3000rpm. If it goes past then you've not got a PRO, if it lets all hell loose with pops and bangs at 3000rpm then you've got L/C. Then set the L/C revs to what ever figure you want the limiter to kick in at. |
#5 (permalink) | |
Jim - It turn on automatically every time your speedo reads 0mph (i.e at standstill) and turns off when you move. I'd always test it on a hot engine personally, it nots worth breaking sometime over a 5 min wait.
Dragging with the L/C at 3500rpm mine built 0.8bar of boost sat still but the boost meant my launches were huge smokey-tyred filled affairs! ![]() |
Just gone into SETTINGS then REV/IDLE (bottom right)
The options were: REV LIMIT F/C A/C F/C A/C IDLE A/C IDLE A/C I tried one at a time to set the limits to 2500, then went back to MONITOR and revved the engine - it sailed past 2500 each time??!? Am I being thick or does it look like my Pro is in fact just a normal PFC? |
REV LIMIT - Your rev limit (!!!)
F/C A/C XXXX - Fuel cut speed AC off F/C A/C XXXX - Fuel cut speed AC on IDLE A/C XXXX - Idle speed AC off IDLE A/C XXXX - You guessed it, Idle speed AC on. That lot are from the non-pro version. I `thought` you needed the software to set the lauch control (Datalogit)? |
It's the 1st/top F/C A/C figure thats the L/C (it was on mine) so if it sails past without lots of popping and banging (like below) WHEN the cars NOT moving then you may not have a PRO
To check go into the ETC menu and select Version - thats should say PRO! |
#14 (permalink) |
Banned
Jim ... do you care?
Kakimoto Exhaust for Sale tulibu dibu douchoo 360 spinner at Spa Jaffa survived a trackday with me MX5 VR limited Combination A RK500 with Serious Performance バジエ アールケイ 五百 = セリウズ パフォーマンス |
