Old 29th October 2005, 12:59 PM   #1 (permalink)
ADMINISTRATOR
Mookistar's Avatar
Is boost uniform?
I mean, I've got some rebuilt R33 Tubbies coming, with steel internals. I'm not sure of the actual spec, but i imagine they are simply standard R33 spec, only without the scary ceramic bits
My question
I currently run 1 bar on an Abbey ECU. If i whack on the Steelies and still run one bar, does the car need remapping? Or will the turbo's work just the same as my ceramics, only with the oppurtunity to up boost with a remap at a later date?
thanks
mook
FOR ALL GTR FORUM RELATED ISSUES CONTACT THE ADMIN TEAM 'MOOKISTAR' OR 'MOLEMAN'
SKYLINE FAQ'S!
Old 29th October 2005, 01:18 PM   #2 (permalink)
Boost pressure and airflow are hugely different, but if the wheels and housings are standard size and style (just with a metal exhaust wheel rather than ceramic) then they will flow the same at the same boost, so yes.
Old 29th October 2005, 01:43 PM   #3 (permalink)
ADMINISTRATOR
Mookistar's Avatar
thank you. That was i thought. wasn't sure if the steel turbo's would give a different boost characteristic and cause running problems
cheers
mook
SKYLINE FAQ'S!
Old 29th October 2005, 02:02 PM   #4 (permalink)
Pikey's Avatar
They'll probably spool up a bit later, as that was the reason behind using ceramic wheels in the first place I think.
Old 29th October 2005, 02:48 PM   #5 (permalink)
ADMINISTRATOR
Mookistar's Avatar
i had wondered if lag would increase from a percived "heavier" wheel.
but so long as the mapping can accomodate that, i'm happy to put up with it.
mook
SKYLINE FAQ'S!
