489bhp on standard AFMs?
General concensus is that the standard GT-R AFMs are max'd out at circa 420-450bhp.
I bought Matt Jeff's R33 RB26DETT that had been treated to the Middlehurst 500 upgrade. I got the job lot and basically whatever came out of Matt's engine bay came as part of the package. The AFMs that Middlehurst use are the standard ones - 65mm internal diameter and the same code on the brown sticker as my OE R32 ones. Yet my own standard R32 AFMs were retained and when RK fitted the engine and got it mapped he managed to get 489bhp & 450lb/ft of torque whilst still using the standard AFMs. That was at 1.3 bar, albeit having to use octane booster. I've just got my new fuel pump (Bosch 044) and have some nice clean filters on the way before sending the car for a remap. Just wondering whether or not I'll need to spunk another few hundred squids on uprated AFMs, and if so, which ones? Jim (so much for a cheap Xmas....) |
Yes- PFC.
I had a chat to Andy Middlehurst yesterday, as it was Middlehurst that originally did the 500bhp upgrade. He told me that the standard AFMs are retaining for 500bhp as they can handle the level of air flow required. Going much further upwards from 500 (e.g. 550+) necessitates Nismo AFMs but the OE ones should be perfectly fine for supporting 500bhp... |
I am a total newbie when in comes to RB26, but I have modified the 3S-GTE for about 4 years now.
Am I right in thinking that the upgrade consisted of Middlehurst using some kind of aftermarket ECU - Apexi Power FC or HKS F-Con Pro? Therefore wouldnt these ECU's use a MAP sensor and get rid of the need for AFM's? ![]() |
Not ignoring what's already been said in this thread, it's worth mentioning that it is possible to get a bit more power from an engine than the AFMs will read though your mapping might not be very accurate at the top end.
For example, if your AFMs max out at, say, 6500rpm and beyond that don't register any more air flow, under the simplest circumstances you'd expect the mixture to start getting leaner from that point. If you were running excessively rich at 6500rpm then at (say) 7000rpm the mixture might have leaned out to a better value and consequently allow you to make a bit more power than the AFM's metering max. Some aftermarket ECUs may (total guess) allow you to program in a richer mixture at high rpm where the AFMs are maxxed out. This might serve to compensate (approximately) and keep the mixture more or less right. It's not going to be very accurate but it's better than nothing. Obviously, it's better to have AFMs that meter the flow properly. |
