Originally Posted by r33 v-spec
The Nismo MFD V2 will unlock the G-Meter, a lap timer, boost gauge up to 1.0bar, water/oil temps start at 50 degrees celsius instead of 70 on the stock MFD. You are also able to download data to your laptop via a RS232 cable and software.
Also on non V-Spec models, this will unlock the exhaust temperature and inlet temperature.
I would say you need 2371B-RSR48 kit
i assume you meant boost guage up to 2.0 bar? as the one i have now does 1.2 bar as it is.
thanks for the other info though
