Twin turboing a GTSt
Seeing as this is the land of the twin turbo i thought i' ask if anyone has info on converting a GTSt from single to twin turbo and what's involved.
I have 2xTo4 turbos and i know someone with a spare GTR exhaust manifild. We run nitrous and a large HKS FMIC with a mines ecu presumably with the matching injectors i'm told come with it. The car came in like this and we want to run it on the strip even though it's not the best at getting the power down i thought it might be fun to TT it. Not sure of the finer points or even the power i could expect. Any info will be read with interest. Chris |
Even the smallest T4s are good for well over 400bhp, most far more, so twin T4s would be well OTT and take for ever to spool up.
A Mines ECU is just the standard ECU re-chipped, so would be useless once the spec was changed. No way T4s would fit a standard GTR manifold anyhow, even if there was room, which there isnt, the flanges are different. There no reason to mess with TT setups really anyhow, a big enough single turbo can give you as much power as you ever want too, with no real disadvantages. |
Gone
As Steve said,
Total waste of time to achieve what a good single turbo can achieve even on stock internals of a GTST. Too many other considerations to go to TT. Most of the GTST stock components are good for 400 hp (as long as the turbo internals are uprated). With good mapping and a good turbo, there's no reason why you cant push an easy 400 and to be honest be a lot less laggy than a GTR of similar power, and just as much fun too.
( OO\ SKYLINE /OO) GTROC Artwork/Calendar Designer 2002-2008 Get your 2009 Calendar here ---> http://www.gtr.co.uk/products-86.html CAPTAIN BLACK - LIFETIME MEMBER #070 The New Book is out :) http://www.gtr.co.uk/products-64-toV...g_marvel_.html |
I'm interested in the output on standard internals for a GTST, I want round the 400 bhp out of an R33 GTST, any advice on the hows and whys?
(I'm a newbie so I'll start the rounds to the meets next yr, can't wait) |
Speak to a guy on here called "Mambastu" ... he's got a 200sx which he's dropped and RB25 into from a 33 GTS-T ... and then he's twin turboed it. He' should be able to offer some advise - if you definiately want to TT the GTS-T.
I've had the pleasure of going out in it too .... goes SUPERBLY well. ![]() |
#6 (permalink) | |
I have a GTS-t engine in an RGTS-t, it gives 490 BHP on decent fuel, reliably, on an engine dyno (no funny rolling road figures ). The bottom end is factory stock apart from a freshen and decent rod bolts. It gives about 460 on pump fuel. Mods are cams, injectors, Power FC, bigger AFM, bigger fuel pump, Apexi turbo and wastegate on Apexi manifold, big intercooler, lots of mapping. The power is more a stock chassis on decent dampers can handle. I have made substantial chassis mods, it was a death trap before.I can duplicate the engine and map too ![]() |
My gtst is running 430bhp, on standard internals,only mods are rebuilt turbo, 555 injectors, z32 afm, 250lhr pump, intercooler, induction kit. no need for a twin setup, stick with the single.
#10 (permalink) | |
IMO twins are well worth it. need a nice forward facing plenum, decent IC and new manifold though so it isn't the cheapest route to take. /Steve
tdi |
