R32GTR/GTST aftermarket suspension parts interhcangability?
Ie front and rear camber arms, toe arms, tie rods, coilovers, top mounts, and so on.
I think they are, but dunno... ![]() |
I think.........
Coilovers:- Rears Yes. Fronts No. Unless GT4 which is same as GTR. Rear Camber Arms:- Yes Front Gubbins:- No. But GTST is same as 200sx IIRC. No 100% but pretty sure if you consider drive layout it makes sense. Hope this helps. Last edited by JB.; 6th December 2005 at 07:03 PM. |
Rear lower A arms and both upper arms are same on all 32's and S13's.
S14's, S15's, R33's and 34's all use different arms apart from the rear upper fwd ones. Just the Hicas links (or lack of) that are different. Most of the Nismo uprated bushes share the same part numbers except the forward rear subframe bushes. At the front the GTS4 and GT-R have a different lower arm arrangement to the lower model 32's. Twin ball joints and forged arm. vs. an inner rubber bush and pressed steel arm. |
