Old 2nd May 2006, 04:22 PM   #64 (permalink)
Hugh Keir
Hugh Keir's Avatar
You didn't say which motor you were going to use to power the throttle.
Motec recommend the fly by wire motor that is used on the M3 and the M5.
I have one at home which I can give you pictures / dimensions if you need.
Fly by wire is great for antilag, cruise control etc, but I am not certain that it gives quite the same level of response that you get with a throttle cable.
