The PAS is now fitted.
The PAS bracket need a little modding. On the RB26, the top bolt goes into the head where as the RB30 doesn't due to the extra block height.
I had to cut off the lug so all 3 bolt holes were the same height.
Here it is fitted.
My PAS pump is a modded R32 pump, not that it effects the mounting.
Here is the finished plumping under the plenum.
There isn't much to it really. I had already binned the idle speed bits, the oil heater/cooler and some of the vacuum pipes.
I thought I'd photo the RB30 and RB26 bottom pulley crank bolts. The left is the RB26. Although the bolts are different, the pulleys are interchangable.
Here is a 'getting there' photo.
