I'm still undecided on the turbo bracing idea. As the manifold gets hot, it moves. If you brace it, the movement won't occure but the manifold will become stressed. Constant stressing will cause a fracture at some point.
I'll probably not for the mo unless someone can convince me...
Brace brace brace brace, did i mention you should put a brace on it? Manifolds definately last longer when there is bracing to support the turbo.
