Wayne,
okay 1st I presume your car has Standard turbo,s fitted if so you MUST not run your car over 1.0 bar boost otherwise the turbo will bnreak and it may cause a expensive engine rebuild.
2, The Blitz ECU will be mapped for 100 octane Jap fuel so the ignition timing will need to be retarded to suit UK fuel.
3, the car if it misfire at 0.6 and doesnt misfire then misfires at 0.8 it coul dhave the following faults; 1, spark plugs worn out 2, coild breaking down 3, fuel pump worn out 4 , ignition amp breaking down. 5, crank angle sensor faulty.
4, this car will run approx 360ish bhp "correctly" set up. Have you got front pipe, dekat pipe and exhaust system fitted?
hope that helps.
Mark
