front tire size - GT-R Register - Nissan Skyline and GTR Owners Club forum
Go Back   GT-R Register - Nissan Skyline and GTR Owners Club forum > General > General Nissan R35 GT-R Chat
Like Tree3Likes
Old 7th January 2017, 08:07 PM   #1 (permalink)
wd1506 is now running R35 and RR Sport
wd1506's Avatar
Cars owned: RR Sport autobiography, GTR, citroen DS3
Unhappy front tire size
i am coming off a square set up and fitting 305/30/20 rears.
but there seems to be some confusion over what size the fronts tires should be.
please help if you can.
wd1506 is offline   Reply With Quote
Old 7th January 2017, 08:21 PM   #2 (permalink)
terry lloyd is unaware they can edit their status
terry lloyd's Avatar
just checked mine mpss 305/30/20 rears 275/35/20 fronts
Old 7th January 2017, 08:24 PM   #3 (permalink)
wd1506's Avatar
Thumbs up
TOP MAN thanks for that.
Old 7th January 2017, 09:35 PM   #4 (permalink)
Chronos is ripping up the tarmac with Godzilla
Chronos's Avatar
Cars owned: R35 Black Edition
What he said^^
R35 GT-R Black Edition
Old 8th January 2017, 06:08 PM   #5 (permalink)
dudersvr is A Legend
dudersvr's Avatar
Cars owned: Stage 4.5,Litchfield 102mm exhaust and Intakes,Linney suction pipe, Syvecsa AWD AC Speedtech FMIC, AC Spec BB turbos, AC map
The 888 set is 285/35/20 and 305/30/20, perfect match for the 285 front is 335/30/20 that is identical tyre height but loads run the first combo with no bother as Toyo dont do a 335
Old 9th January 2017, 01:37 PM   #6 (permalink)
ACspeedtech is getting bigger and faster!
GTR Register Trader
Exactly right, please do check your sizes on a calculator as there are a lot of setups that will end up overworking the ETS unit and cause transmission problems. Stock is around 0.6-0.7% difference, anything over 1% will start being a little 'active' (you'll see the torque split flicking to AWD on the MFD on part throttle)
NEW SHOP NUMBER! Please call 01925 830889.
NEW PREMISES! ACspeedtech, E1 Trident Ind.Park, Birchwood, WA3 6BX.
EcuTek MASTER Tuner - COBB ProTuner - 6T9 - Motul - KW - ADV.1 - Pentosin - Carbotech - AP - HEL - Eibach
ACspeedtech custom GR6 gearbox upgrades - GR6 transmission repairs and solutions
Visit our website at:
Check out our fb page at:
ACspeedtech is offline   Reply With Quote
Old 9th January 2017, 01:48 PM   #7 (permalink)
Good to see a shop getting involved whats your thoughts on the 305 rears and 275 front set ups
Old 9th January 2017, 01:54 PM   #8 (permalink)
Stealth69 is missing the GT-R, damn you Winter!
that puts them at 1.4% difference........ can't be good right?
Old 9th January 2017, 01:56 PM   #9 (permalink)
Hmmmm thought it was over the 1% thought that was the known size to go for
Old 9th January 2017, 02:00 PM   #10 (permalink)
315 would go lovely
terry lloyd likes this.
Old 9th January 2017, 02:05 PM   #11 (permalink)
GTR Register Trader
To be clear, 'over 1%' will not immediately break it, but it will be a little more active than originally designed. We also see a difference on the model years of cars with the different software versions too.
Best advice is to stick to the minimum tyre size difference you can, if you've non standard tyre sizes, keep an eye on the AWD torque split and check it isn't surging while driving or being overly active on sweeping corners.
Stealth69 and terry lloyd like this.
Old 9th January 2017, 02:09 PM   #12 (permalink)
GTR Register Trader
315 would go lovely
Yep, the 275/35 and 315/30 is good (0.5%), 285/35 and 335/30 is also good (but rather wide, I wouldn't confirm this would clear and defo not on a stock wheel)
Certain model years and software version are a little easier on the differences for sure, just be aware on the torque split when you initially fit non oem sizes.
Old 9th January 2017, 08:19 PM   #13 (permalink)
colin41 is unaware they can edit their status
Am I right in saying a 265-35 x 305-30 combo would be even closer than standard?
If so I'd sacrifice 10mm on the front for a happier ets unit.
I just checked the new 4s tyre sizes and the 265-35 has a noticeably less load rating.
colin41 is offline   Reply With Quote
Old 9th January 2017, 09:20 PM   #14 (permalink)
On the MPSS if i remember correctly they either did not do 265 or they did not do them in XL
Old 9th January 2017, 10:37 PM   #15 (permalink)
Michelin Pilot Sport 4 S Press Release - Tyre Reviews
Maybe they do now?
Old 9th January 2017, 11:06 PM   #16 (permalink)
Tin
Tin is a Nutcase.
Tin's Avatar
Yes thats correct, they do them in the cup2 xl size though, 265 & 305.
Old 10th January 2017, 08:46 AM   #17 (permalink)
GTR Register Trader
Yes, those are a very good size combo, I've heard rumours they are bringing a higher load rated 4s out, I think they'll be getting pestered at the Autosport show on Thursday about that.
Old 10th January 2017, 01:19 PM   #18 (permalink)
dudersvr's Avatar
305/30/20 is 27.2" tall, 265/35/20 is 27.3" tall
Old 10th January 2017, 06:55 PM   #19 (permalink)
dudersvr's Avatar
335 rear does clear and still leaves big black lines
Old 10th January 2017, 07:24 PM   #20 (permalink)
GTR Register Trader
Cheers John! 335s on stock wheel with no spacers? Just to confirm for other interested chaps.
