Skyline frontal impact strength - GT-R Register - Nissan Skyline and GTR Owners Club forum
Go Back   GT-R Register - Nissan Skyline and GTR Owners Club forum > General > General Nissan Skyline Chat
Like Tree13Likes
Old 12th April 2017, 05:14 PM   #1 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
Something that is overlooked but the reality is that all 3 models of the Skyline GTRs have very poor front end impact structure.
Some pictures I found on social media (apologies if it's someone here and does not want them up, contact me and I'll remove them)
It is no surprise to see the Ford Ka faired much better than the R33 GTR. Apart from driving safer, fitting a cage spot welding front end and extending the roll cagine into and reinforcing the engine bay there is not much else that can be done to improve front end safety. Then you need to factor in and make sure there is a crumple zone to dissipate impact energy. Not an easy thing to do.
"They both - Nismo and HKS look like very expensive pieces of aluminum pipe. I suggest you modify the stock twin turbo pipe, and take the rest of the money, and donate it to single mum's down at the local gentleman's establishments"
Old 12th April 2017, 06:58 PM   #2 (permalink)
AlexJ is as AlexJ does
AlexJ's Avatar
Cars owned: BNR32 HCR32
Horribly sight and the side impact protection is very poor too, I was certain I wanted at least a 6 point cage and door bars before taking mine on track.
FRRACER likes this.
Old 12th April 2017, 07:16 PM   #3 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
Sorry meant seam welding not spot.
Old 12th April 2017, 07:17 PM   #4 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
Makes me think about getting a full weld in cage too seeing crashes like this. It is not limited to the R32/33 only the R34 is just as soft or as bad as the R33. R32 is the worst out of the lot.
Old 12th April 2017, 07:21 PM   #5 (permalink)
jdm4life is fully aware they can edit their status but doesn't see the point
How rusty were the rails? That rust on the towers?
jdm4life is offline   Reply With Quote
Old 12th April 2017, 07:52 PM   #6 (permalink)
Mookistar is a lover of steak but fed up with Beef
Site Admin.
Mookistar's Avatar
Cars owned: Mookiwagen Passat and R33 GTR
You can't drive with a cage without a helmet. You'll save the car but you'll need a valet to remove your brains from the upholstery.
SPEED MERCHANT likes this.
Support the forum by Supporting our Sponsors.
View my Garage -
- then set up your own!
Now on Facebook -
Old 12th April 2017, 08:22 PM   #7 (permalink)
AlexJ's Avatar
Depends. Leaving cages to one side, if your head makes contact with anything other than an airbag in a crash and you are in trouble.
Even with a helmet on, contact with a roll cage is no joke. A cage needs a restrained driver, 6 point harness ideally, proper "padding" (misnomer, FIA stuff it is rock hard) and enough clearance to avoid contact in an impact imo. And of course a helmet ideally, but properly setup its not a massive additional risk on the road without one, unless you treat the road like a track.
Old 12th April 2017, 08:50 PM   #8 (permalink)
AlexJ's Avatar
RUF make cars with integral cages, Ginetta, Ultima and a few others are similar; exposed or alcantara trimmed cages. If they were fundementally unsafe these cars wouldn't meet standards required for sale; TUV, Type approval or whatever. Just depends how you do it.
In an R32/S13 it is very hard to fit a 6 point cage and a proper seat and have adequate clearance without lowering the seat mounting points.
Overlapped impacts like the one above is something that older cars and skylines especially bad in. Modern crash tests mean standards are much higher now.
Old 12th April 2017, 09:13 PM   #9 (permalink)
lightspeed is Fixing a Laminova leak
lightspeed's Avatar
Cars owned: Project BNR32
Longitudinal engine layout is also not as good in an overlap impact as the drivetrain misses and the shell takes all the energy.
As for cages it depends if your head can easily hit the bar. Tall people, skylines and cages aren't a good mix.
AlexJ and m.a.fleming82 like this.
lightspeed is online now   Reply With Quote
Old 12th April 2017, 09:15 PM   #10 (permalink)
TAZZMAXX is shaking his head
ADMIN
TAZZMAXX's Avatar
Cars owned: Fiat 500L, Honda Prelude 2.2 vtec 4ws, Prelude 2.0 - The Elf
You can, you just need the correct 4 or 6 point harness to hold you in place rather than a standard inertia reel seat belt. As long as you can't come out of the seat, your swede will be safe
mambastu and AlexJ like this.
Old 13th April 2017, 12:39 PM   #11 (permalink)
Owner of the MSNSPS
Cris's Avatar
Cars owned: BNR32, RGV, 330i
Interesting point safety. Of course the older cars are not as safe as the new ones. I suspect the majority of the improvements to crash safety numbers come from modern safety systems.
The question to ask is what is your limit? Motorbikes are not safe compared to cars. Push bikes the same. I see guys riding about with flip flops on...
Old 13th April 2017, 12:41 PM   #12 (permalink)
Owner of the MSNSPS
Cris's Avatar
Don't suppose you know anyone who can do a cage like the ones Ruf use?
Normal cages are too obtrusive in an R32 for my liking
Old 16th April 2017, 05:53 AM   #13 (permalink)
joshuaho96 is unaware they can edit their status
Food for thought: one of the major changes made to the Skyline GTRs during the early days of import into the US was crashworthiness improvements. Maybe once all Skyline GTRs are FMVSS exempt there will be a release of information on the modifications done to bring the 1996-1998 R33 GTRs into FMVSS compliance.
The MotoRex cars don't have visible cages so it's probably strategic welds and reinforcements in order to pass crash safety.
There may also be chassis rigidity improvements derived from such reinforcements. In this crash you can very clearly see that the safety cell collapsed. I would be shocked if the driver of the Skyline escaped unscathed.
joshuaho96 is offline   Reply With Quote
Old 16th April 2017, 06:41 AM   #14 (permalink)
anthonymcgrath is probably succumbing to gravity... lemme check.. yep.. still there funnily enough
anthonymcgrath's Avatar
Cars owned: R33 gtst
They shrinkwrap you when crashed. Very old cars esp the R32 models.
Sent from my SM-A520F using Tapatalk
anthonymcgrath is offline   Reply With Quote
Old 16th April 2017, 07:14 AM   #15 (permalink)
Huskyman is in limbo
Huskyman's Avatar
I thought about this long and hard when I was looking into buying an R32 back in 2011(boy did I miss the boat!) and looked into the crash worthiness of these cars. A Ruf style integrated would be a big leap forward, but remember the 911 is a strong and stiff car without it, and the cage is around £10,000 installed AFAIK. As joshuaho96 says the MotoRex cars were modified to pass American crash safety, so would it be worth contacting them to see if they could help?
Huskyman is offline   Reply With Quote
Old 16th April 2017, 09:14 AM   #16 (permalink)
It's important to note that Motorex is defunct now. JK Technologies was the company that did the actual work here and they have not been compelled by the government to release the technical data package for FMVSS + EPA compliance.
Old 17th April 2017, 01:03 PM   #17 (permalink)
K66 SKY is no longer a subscribed reader of Evo magazine -The thrill of errrm....Advertising!!!
K66 SKY's Avatar
Cars owned: 1992 Carlton GSi 3000 24v - 1996 R33 Skyline GT-R Standard Spec II.
Scary, Those pictures are truly shocking FRRACER. I do hope that all those involved in that accident were Ok.
True...We Humans don't react well to side impact head trauma but that's not the only concern lightspeed. I thought long and hard about fitting a Cage to mine back last year (even contacted members on here who'd fitted ones to their Skylines for their opinions) but I ultimately decided against going for one in the end.
I know that Roll Cages do save lives but all the multi-point bolt-in versions I've seen available for Our GT-R's seem to have the vital bolt in parts located in what on some can become quite flimsy areas of the Skyline cockpit.
You only have to look closely at the front of an R33/R34 that's been jacked up poorly on the front lower Sill area to see how the incorrect loading weakens the Shell's integrity as the Sill lip gets crushed, the inner Sill bottom distorts and the Floor Pan splits spreading both upwards/inwards destroying the water repelling duties of the Factory applied primers/paints/seam-sealers in the process.
Given a very short amount of time, water ingress turns everything hidden inside the vicinity of the Sills crushed Jacking Point into a crusty rusty mess with little to no impact strength left!
This corrosive badness all happens within inches of what would be one of a Roll Cages main bolt in point locations (and of course Our feet too!) which eventually lead me to question the crash worthy effectiveness of such a safety device retro fitted to such an old vehicle.
The rear wheel well bolt-in locations seem better but alas I do wonder about the overall bolt-in cages effectiveness if the first front bolt-in location would most likely punch through the Cars flimsy floor pan in a crash situation....
For me, a proper multi-point professional weld in Roll Cage like what's seen in high end Motorsport (WRC/V8 Supercars/DTM/BTCC etc) would be the only safe option BUT these would be hugely expensive, massively intrusive to the cars cabin restricting in and out movements and thus destroying the vehicles practicality of being a Family friendly everyday Road Car.
JM2PW!
Cris and FRRACER like this.
Passionate about old RWD Vauxhall-Opel's from the 1980's and 1990's but my Skyline GT-R is totally in another league and blows them all away!!!!
K66 SKY is offline   Reply With Quote
Old 21st April 2017, 12:52 PM   #18 (permalink)
jimjam92 is 94 R32 GTR 96 Supra TT
jimjam92's Avatar
Wow, these pictures are a real eye opener :O
jimjam92 is offline   Reply With Quote
Old 21st April 2017, 01:41 PM   #19 (permalink)
alexcrosse is unaware they can edit their status
Bolt in roll cages don't just 'punch through the floor'. You weld in 3mm steel load spreading plates. It's not really any different to a weld in cage once you've done that.
See the four spreading plates I fabricated for a 205 shell a few years ago. Also included front towers out of 3mm for the front legs.
FRRACER likes this.
alexcrosse is offline   Reply With Quote
Old 21st April 2017, 02:50 PM   #20 (permalink)
K66 SKY's Avatar
Your Car may come with these vital safety features fitted alexcrosse but I have seen a few Skylines over the years which did not have any extra reinforcement done to these areas....
I guess its ultimately all down to who fits them and if they are just for show or for functionality at the end of the day?!
