Go Back   GT-R Register - Official Nissan Skyline and GTR Owners Club forum > General > Members Gallery
Old 8th March 2006, 05:25 PM   #1 (permalink)
R 32 GTS Drag spec
it`s originally a R32 GTS.....not a GTS-t or a GTR and it`s built for dragracing....by me
Engine
Rb 26 Dett N1
concrete filled eng,block ,machined and drilled
crossflowing water chanels in upper part of eng,block and cyl.head
modified oil chanels, external 30X40 cm oil cooler
stock water pump removed,electric water pump is used ,
Cylinder head
cnc-modified combustion chambers .ported and flowtested
larger valves , custom valve-springs and retrainers,
camshafts 11.8 mm lift ,opens in the evening and close at night
(sorry don`t want to give away everything)
Heat hardened steel crank, carillo rods modified for larger piston bolts
Je pistons with custom bolts
stainless steel tubular exh,manifold , modified AMW -Wastegate
Garret GT42R BB with 102 mm impeller
Dry sump lubrication system
Jun inlet-manifold with 90mm trottle
bosch 1680 cc injectors
the Engine runs on alcohol
Gearbox:chevrolet TH 400 shifted manually with transbreak
and high stall turbine
rear axle Ford 9" with 4-link and double adjustable shocks,
Moroso 4"frontrunners 12"MH Slicks ,Nos
and much more other stuff i forgot at this moment
Built and runs in Sweden
these are old pictures
lots have been changed since
have a few pics if someone is interested
Maxout
Maxout is offline   Reply With Quote
Old 8th March 2006, 05:29 PM   #2 (permalink)
Neale's Avatar
Send a message via MSN to Neale
concrete filling? Whats all that about?
Fab car though, whats times has it ran?
Neale is offline   Reply With Quote
Old 8th March 2006, 05:47 PM   #3 (permalink)
well its actually a form of epoxi , the heat transfer in the cylinder gets more even,,,,,due to the extreme heat in the upper part of the cylinder
during full trottle and the fact that you try to run the engine cold 60-70 deg C the temperature difference is to big in the upper compared to the lower part of the cylinder and the concrete(epoxi) evens it out
and it also stiffens up the cylinder walls
and it dampens vibrations ,protecting the eng,block from cracking
Maxout
Old 8th March 2006, 07:19 PM   #4 (permalink)
Banned
Bajie's Avatar
Send a message via MSN to Bajie
Some pics of the car in action please
Kakimoto Exhaust for Sale
tulibu dibu douchoo
360 spinner at Spa
Jaffa survived a trackday with me
MX5 VR limited Combination A
RK500 with Serious Performance
バジエ
アールケイ 五百
= セリウズ パフォーマンス
Bajie is offline   Reply With Quote
Old 8th March 2006, 07:31 PM   #5 (permalink)
Haribo's Avatar
Send a message via MSN to Haribo
that looks killer mate.
Haribo is offline   Reply With Quote
Old 8th March 2006, 07:41 PM   #6 (permalink)
Not seen the weather this time of year in Sweeden then?
Might not be finished either, certainly isnt in the enginebay pics.
Once the sumer comes along this car has all the potential to run 8s, proper drag rear end with transbrake n allsorts.
Semi-filled block too, no messing about there, serious drag engine
Old 8th March 2006, 08:04 PM   #7 (permalink)
Haribo's Avatar
those scandanavians dont do things by half!
Old 8th March 2006, 08:13 PM   #8 (permalink)
Dohc's Avatar
Send a message via MSN to Dohc
it has the same bodykit as mine...
great job you´ve done there m8,congratz
Dohc is offline   Reply With Quote
Old 8th March 2006, 09:54 PM   #9 (permalink)
justinfox's Avatar
Holy shiat!!!
justinfox is offline   Reply With Quote
Old 8th March 2006, 10:19 PM   #10 (permalink)
beario's Avatar
wicked gearbox...the th400...i run the th350 in my rx7...top looking car...
beario is offline   Reply With Quote
Old 8th March 2006, 10:58 PM   #11 (permalink)
Thank`s all for the positive comments
The car is in parts for the moment, prepared for work of fitting a full
prostock roll cage, the old cage (jap-driftcage) didn`t meet up with drag regulations, so that had to go, also fitting wheelie bars,brake parashute
and larger diameter rear tires 26"now up to 32" ,14" wide,
most work is in chassie preparation making the car react as as we want
up to this point the car has only run a serie of tests , breaking in the engine
checking chassie reactions ,sorting out driveline components and such
it has not done any official time runs ,
Maxout
Old 9th March 2006, 10:53 AM   #12 (permalink)
Banned
Bajie's Avatar
Worked in Kista Nov 97-Jun 98. Lived in Nor Malastrand near Fridhemsplan station.
Pictures were old ones so thought he might have had some "before" pictures of the car when he got it.
Its all good though
tulibu dibu douchoo
360 spinner at Spa
バジエ
アールケイ 五百
= セリウズ パフォーマンス
Old 9th March 2006, 01:10 PM   #13 (permalink)
petey's Avatar
what sort of power and torque figures?
petey is offline   Reply With Quote
