Asim, I was worried I couldn't use a STD gasket with an 'O' ringed block, but you say I can. Is this recommended??
It is very common with cosworths and volvo`s here in Norway to use standard head gasket when the block has steel o-rings. And it does the job!
What thickness rings do you have? and how deep is the groove for the rings?
