If you could find what I'm supposed to use, that would be super.
had a good look on the net for ya but couldnt find anything the same over here in uk......... if you take the time and clean the block, gasket and head
up, you could seal around each water/oil gallery using loctite 574 flange sealer ( being very careful not to put too much on so it doesnt go where it shouldnt ) that would work better than the spray!!!!
