Help, getting fed up now :( - GT-R Register - Nissan Skyline and GTR Owners Club forum
Go Back   GT-R Register - Nissan Skyline and GTR Owners Club forum > General > General Nissan Skyline Chat
Like Tree3Likes
  • 2 Post By Marc7680
  • 1 Post By Red Duke
Old 19th June 2017, 02:30 PM   #1 (permalink)
Marc7680 is unaware they can edit their status
Hi all, keep getting small issues that are winding me right up I've had missfire after missfire, replaced the coilpack loom resoldered the mafs replaced the ignition amp and found a boost pipe off in the last few months all problems that have given me the dreaded missfire.
Yesterday she was running lovely, went out for my Father's Day lunch in the forest and I was feeling so happy with the car.
On the way home after a nice long drive It started missing when under boost but was completely fine when driven off boost. It was a super warm day as well, would my plugs cause this or are coilpacks my next step.
Marc7680 is offline   Reply With Quote
Old 19th June 2017, 02:31 PM   #2 (permalink)
Mookistar is a lover of steak but fed up with Beef
Site Admin.
Mookistar's Avatar
Cars owned: Mookiwagen Passat and R33 GTR
checked the ECU plug? Make sure it's done up nice and tight
Support the forum by Supporting our Sponsors.
View my Garage -
- then set up your own!
Now on Facebook -
Old 19th June 2017, 02:51 PM   #3 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
Chinese coils?
"They both - Nismo and HKS look like very expensive pieces of aluminum pipe. I suggest you modify the stock twin turbo pipe, and take the rest of the money, and donate it to single mum's down at the local gentleman's establishments"
Old 19th June 2017, 02:59 PM   #4 (permalink)
Red Duke is under a pile of Nismo!
Red Duke's Avatar
Cars owned: QM1 R33 GTR & Mazda 6 2.2 Sport Diesel
The last time I had this issue, I had a split in the hose going from the intercooler into the twin turbo pipe! Wasn't noticeable until my finger went into it (hoho!) - the split was underneath and slightly to the side. I bought new coilpacks only to find out it was a £20 hose!
I might have an old set of coilpacks I left in my parents garage from my previous GTR, if I find them you can have them, might be worth a try before shelling out unnecessarily!
Have you driven the car now it has cooled down? Does it still do it? Might be worth whipping off the coilpack cover, it does get hot in there, won't help if your coilpacks are a bit temperamental!
Old 19th June 2017, 04:31 PM   #5 (permalink)
I haven't driven it since but will have a go shortly, thank you for the kind offer of trying your old coil packs that's a very gentlemanly jestjure. My first boost missfire was due to the vac pipe coming off the fpr so first thing I will do is take it for a drive and see what happens.
My coilpacks are standard and old btw that's why I can't rule them out yet,
Old 19th June 2017, 04:53 PM   #6 (permalink)
David's Avatar
Cars owned: R33 GTR, Supra Big Single, RWD minipickup, 330D M Sport, Boxster S
It sounds like you have another boost leak, assuming the first was caused by a damaged hose it may be a good idea to replace all the hoses as these cars are now getting on a bit
Old 19th June 2017, 05:02 PM   #7 (permalink)
The same jubilee clip! Grr it's damaged and I pulled it off wth my hands.
Annoyingly I haven't got a spare until tomorrow
Old 19th June 2017, 05:02 PM   #8 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
If it is your coil packs what ever you do don't buy the Chinese ones. Go genuine or Splitfire.
Old 19th June 2017, 05:05 PM   #9 (permalink)
David's Avatar
Replace all of them otherwise you will be continually chasing the weakest link
Old 19th June 2017, 05:07 PM   #10 (permalink)
I won't, I will probably go genuine anyway.
This jubilee clips looking like the problem, fingers crossed
Old 19th June 2017, 08:29 PM   #11 (permalink)
Good news I have replaced the jubilee clip and all is lovely once again, been for a long drive and we are issue free. I think I'm pretty sure I know why it failed as well..
After the first time this one clip came off and the car ran like crap, I stupidly tightened it with my impact gun with an 8mm bit fitted. Thinking it was nice and tight what I failed to realise was that the four small spot welds had actually broken on the clip. Then a good drive Sunday obviously worked it loose.
It's amazing how much even a small boost leak effects these things it's quite shocking !!
Anyway thanks for all the advise and red duke for the offer of parts to help...
this is a lovely helpful forum
Red Duke and Josh91 like this.
Old 19th June 2017, 09:29 PM   #12 (permalink)
Red Duke's Avatar
No problem matey I can recommend the Mikalor / T-bolt clamps, great even pressure and don't strip the threads like the older jubilee clips! Glad you got it sorted, worst feeling on the world is a poorly Skyline, it's usually expensive!
MS33 likes this.
Old 25th June 2017, 06:10 AM   #13 (permalink)
Balls, seems that when she's used for a longer period and gets really warm this missfire is back again only on boost other then that she's lovely , plugs and coilpacks next I guess...
Old 25th June 2017, 11:53 AM   #14 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
Coil packs breaking down. Very common remember they could potentially be over 25 years old.
Go igniterless - one less thing to worry about.
Old 25th June 2017, 04:12 PM   #15 (permalink)
JoshThePonce is unaware they can edit their status
I'm pretty sure it will be the coilpacks especially if they are original, had the same issue on mine, went with splitfires not a problem since
JoshThePonce is offline   Reply With Quote
Old 26th June 2017, 06:55 AM   #16 (permalink)
How does that work then ? I've already replaced that bit lol
Old 26th June 2017, 08:12 AM   #17 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
What did you replace it with?
Old 26th June 2017, 08:53 AM   #18 (permalink)
I bought another amp, but have since gone back to the oem unit as the faults exactly the same with both mate
