#33 (permalink) | |
#35 (permalink) |
I don't think the RB30 runs with knock sensors.
With the AEM, you can tune the knock sensors so there wil be no problems there. Like you say, any internal changes ailter the knock, as does screamer pipes etc. If you log the knock voltage, you can see it rises really quickly after about 6000rpm and it makes recognising actual knock quite hit and miss. |
#38 (permalink) |
R32 Combat,
Most of the information I have researched on detonation suggests that the cylinder bore has the greatest effect on the expected frequency of detonation, so the RB26 sensors should be fine. Proposed knock sensor position looks good to me, although I am not certain that the AEM ECU has any real ability to determine detonation levels, it looks to me that the ECU is outputting raw sensor information with no frequency filtering. The image below shows 3 graphs, the top is RPM, the middle graph is from a J&S detonation monitor and the bottom is the output from an AEM EMS ECU supposedly showing raw and filtered signals. Cheers Hugh ![]() |
#39 (permalink) |
There is no frequency filtering that I can see, hence me saying its a little hit and miss. AEM's recommended setup is to retard the timing 10degs, log a flat out run and use that Voltage graph as your base. It seems fairly good, but ising knock sensors with a 0-5v output and a filter would be a much better way of doing it. It's something I'll be looking at later.
Moving on a little, here's my turbo oil return pipework. Again, its a B&Q special and cost nearly a fiver.. The RB30 only has one oil drain hone and its in the middle of the block. I could have made the return go straight into the sump, but I've already fitted it so I went down this route.. ![]() ![]() |
#45 (permalink) |
Soldering on that pipe WILL break, it is to long of an un-supported length. But i think if you put a bracket on it tied to one of the engine mount bolts it will probably last a great deal longer.
