#47 (permalink) |
I'd be interested to know who sold you the crap adapter plate from Aussie. I sold a 4wd RB30 bottom end to a guy over there for his own use and it looks like he's copied it bady and is trying to sell them as his own design. Also I hear there are a few 4wd RB30 motors comming over from aussie, be carefull is all I can say, make sure who you deal with knows what they are doing.
Good luck with yours, it looks good for the most part....Rob
#49 (permalink) |
Thermocouples are now installed and should work ok. Obviously the cable ties will be replaced with something a little better, like bare tinned copper wire.
The reason for having so many is 2 fold. 1) I don't know how well my plenum will work, this should tell me. 2) When tuning an engine, its best to treat each cylinder as an individual engine, as they all run slightly differently. This might seem overkill, but nows the time to do it.. ![]() ![]() ![]() ![]() |
#50 (permalink) |
Not overkill at all, something i wish i had time to play with. Sensor positioning looks good to, fairly equal length and not on the outside of any bends that would cause localised heating.
How far does the probe extend into the runner, and what kind of temps can they monitor/fall to bits at? |
#51 (permalink) | |
#52 (permalink) |
The thermocouples are inconel and measure upto 1100c but melt at 1250c. I chose 3mm dia ones. Although they read slower than say 1.5mm dia ones, they are less likely to break and that seems the STD automotive size.
They stick half way out into the manifold which I guess is about right. My turbos already eaten a bolt, I just hope it doesn't eat these too.. ![]() |
#53 (permalink) |
I have run a 3mm Ø EGT probe before the Turbo on an earlier R33 GTR without any problems.
Your attention to detail is impressive, fingers crossed that all your hard work is repaid with some good results. |
#54 (permalink) |
After another busy few hours..
Note how much the water jacket stickes out the side of the RB30 block. This caused the exhaust manifild to foul a little. To overcome this simply grind/file a bit off the manifold.. ![]() ![]() The exhaust is now mummified, twice in some areas. ![]() Getting the manifold nuts on becomes a tad more difficult due to the increase on dia if the pipes. Notice the silver heat wrap that runs inder the manifold. THats got the thermocouple wires in it. They are rated to 120degs C before they melt. You can get higher rated ones, but I think this will do. ![]() ![]() ![]() Now the knock sensors. I simple ground/filed/stoned the 2 bosses flat and drilled/tapped them M8 making sure I didn't go too deep and enter the water jacket. ![]() ![]() This is what the oil return pipe will look like when its finished. I've had a few teething problems in this area due to my insistance in having a large bore pipe. All the AN- fitting are small bore in comparison to the thread size. 5/8" is what in trying to use, but the pipe is so unflexable, it makes it real hard to fit. I need to make up a proper elbow as I can't buy one to suit my application. ![]() Here is another(nearly finished) front view. ![]() |
#55 (permalink) |
Did you port match the exhaust manifold to the gaskets/head.
My similar HKS T04R manifold is a very poorly shaped on the ports and the big steps will be getting ground before it's refitted. Some big steps |
#57 (permalink) |
Yes, its a HKS T51r turbo. A very robust piece of kit and idealy suited to the extra 400cc for the RB30
I've had a look at flowing the exhaust manifold where it meets the head, but it seems quite good already. It would be good if the manifolw had a more precise location method then the oversize hole, but I assume that allows for heat distortion. The single throttle body mods are coming along well now. I've removed all the butterflys, plugged up the holes and smoothed out the inside. I'll post up some more pics soon. |
#59 (permalink) |
Thanks Yunis, in answer to your question about my choice of pipe, why spend money on stainless steel braided hoses etc when plain old copper pipe will do. I'm not a 'bling bling' person. If it works, then it will do.
There will be some more copper water pipes for the heater/block bypass pipes soon. I will do a few drag runs in it later this year(if everything works ok). I can't run it on the track due to STDish brakes and a screamer pipe. |
#60 (permalink) |
GTROC Member #354
My god man, you certianly know your stuff! I would love to attempt something like this but after reading your thread about 70% of the stuff your talking about I have no clue what it does lol.... and I used to consider myself half knowledgable when it came to engines!
Better re-evaluate my opinion of my engine brain ![]() |
