RB30 engine conversion (lots of pics)
I'm taking photos of my engine conversion for all to see.
I've decided to fit an Nissan RB30 into my 1989 R32 GTR. It's not a super hard job, there are just a few tricky problems to solve. I don't know if my solutions are the best. They are just my solutions. I've asked where I can but some solutions are just not discussed. It's like its some big secret or something. Anyway, I hope you enjoy this thread. The 1st thing to do was fit the Jun oil pump drive collar to the crank. Notice how thin the RB30 STD drive collar is. ![]() ![]() Building the engine. 1st are a few shots of the block after cleaning. ![]() ![]() ![]() Next fitting the crank. All basic stuff so far. ![]() ![]() Next is the oil pump. I chose the JUN pump. It's cheap and quite a large capacity. The 1st photo is the STD pump with the threaded bumg in the end removed. You can see I blocked up the original oil feed hole. The RB30 oil feed pickup pipe is in a different place in the block so it can't be use with the GTR sump. You have to run an external oil pickup pipe. I'll show than in a while. I simply tapped the original feed hole and screwed a plug into it. Easy job.. ![]() ![]() |
The 1st hard bit is the 4WD sump adapter. THe one I bought from Oz was a shocking bit of engineering and didn't fit. I decided to make my own.
This is about half way through fitting. I got my own blanks cut from the shape of the one from Oz. That was about the only thing that was right. ![]() This is nearly finished. It took ages to make this but it was the best way to do it. ![]() There are a few block mods to do as well, but I've not yet photographed them. The next tricky bit is the sump. I bought one from RK tuning with metal sump baffles. These are better than rubber ones. The sump need adjusting for the external pickup pipe. The 1st decision was what pickup to use. Althought the STD head will fit, I opted for a piece 20mm pipe from B&Q. I didn't want to restrict the pipe by putting the strainer gauze over the end so I spot welded the gauze over the gates on the baffle itself. Here are some pics STD RK extended sump and baffle ![]() The STD oil pickup head inside. The flaps do open. There is enough room.(just) ![]() Cut out marked for the new pipe. ![]() The external flange. ![]() The finished inside. ![]() ![]() The external fitting. ![]() |
The water pump..
RB30 and N1 pumps. ![]() Interestingly, here are 2 photos. One is the RB30 and one the RB26. Notice how much taller the block is from the block deck to the top of the water pump. The RB26 is flat and the RB30 is 40mm taller. RB26 ![]() RB30 ![]() The next problem is the gearbox bellhousing bolts don't line up with the sump due to the fact a sump adapter is used. ![]() ![]() To get round this problem, I chose to blank off the holes in the sump and start again. I also pluged a tapped hole and a plain hole in the gearbox too. ![]() ![]() The hole are 10mm out of position, the thickness of the sump adapter. |
#7 (permalink) | |
can be smoothed but i dont think its an issue on this engine like it was on our vaux ones.., i just tickled them to make them less sharp but i didnt remove them, same with the rods andy this is a cool thread ![]() |
The gearbox now fits and all the bolts are in. I'm glad I've got this done now. I had my reservations as to how well it would go but its gone well and I'm well chuffed.
![]() ![]() ![]() This is the external oil pipe bit, I need to get the connecting pipe made up now. ![]() A pic of the front so far. ![]() The next bit is to re-build the head. Boring and very time consuming but I think its a worth while job. I need to see how much damage is caused to the exhaust valve seats by using anti-lag. ![]() |
Brilliant write up, cheers for taking the time to document the build process.
It seems to be coming along nicely so far, best of luck with the remainder of the build. I'm looking forward to seeing this project finished. P.S. Nice slippers. ![]() |
