do you think having no oil squirters will be detrimental to the reliability of the engine??
Or are you mapping the car rich to keep temps down.
Also a friend of mine mentioned knife edging the crank as this does'nt cost much and is good for repeated high rpm use(not that you need to rev high RB30) I s this a worth while mod for me. I will be using the GT35 hopefully with cams, fuel and flow rate of head running 20-25 psi.
Awesome car really need to see this in the flesh. Hopefully see you at some shows.
Thanks for the thread answer some unaswered questions off of
www.skylinesaustralia.com forums
Thanks John
p.s cant wait to find out what the RB20DET - RB30DET Upgrade is like!!!!
