Andy,
Can you divulge who gave you this info about this Nissan Cam/crank angle sensor problem? Was it an AEM source?
There are plenty of 2litre 4 pot nissans using the stock CAS with no reported scatter, and I fail to think why Nissan would put up with a compromised system, when there are loads of fixes.
I'm not following your explanation of the problem. When you say CAS do you mean crank angle sensor? The CAS is the only thing that determines engine speed/position!!!
