Old 27th September 2006, 08:11 PM   #188 (permalink)
Hugh Keir
Hugh Keir's Avatar
Nisfan & Asim,
This is equally a problem on a standard ECU and is not catered for except that it is less of an issue on a 280 BHP engine.
The problem has probably been identified by others, but is initially a problem with cambelt flex that leads to errors in ignition timing that causes uneven ignition timing which then leads to crank flex and so it builds up.
R32 Combat,
I do not know how the AEM works, but I am pretty sure that the workaround Rod has in mind will be a fix for all ECU's, so may help you when it becomes available.
