Andy,
I am thinking the Nissan CAS has a sensor to pick up the 360 slots, and another sensor to pick up cam position slots. i.e. two sensors/wiring circuits in one.
This being the case, surely you could be able to separate these into a crank mounted Hall sensor, and a cam sensor?
If the software allows it, you should be able to tell the ECU the wheel spec (36-1, 60-2, etc) and positioning, for both sensors.
I'm running DTA P8Pro on my RB26, and have cam sensor for full sequential operation. I'm pleased to say, my crank trace/timing is solid as a rock.
I was unsure whether AEM was full sequential on a 6 cylinder? Can anyone confirm?
