When looking through the R34 workshop manual sensor output signals, I noticed that pin 47 of the ECU is stated as a crank position sensor ring gear signal. .
In the R34 GTS service manual I guess it says that. In the R34 GT-R manual pin 47 is the diagnostic signal line.
As far as revs go, probably all about the piston speed at 7200 or 7500 rpms. When I did some calculations the RB30 at 8k was like a RB26 in piston speed at 10k.
