Old 12th October 2006, 10:08 AM   #211 (permalink)
Asim R32GTR
Asim R32GTR's Avatar
Originally Posted by Hugh Keir View Post
sleepyfox,
As far as I understand it, the cam belt flex is induced by the resistance of rotating the cams + crankshaft flex.
As the engine becomes more loaded under high boost at high RPM the crank will flex more with each combustion which causes more inaccuracies in cam and ignition timing.
Removing the ignition timing aspect of the above by triggering the ECU from a non cam belt driven source is a large part of the solution.
How big of a problem is the fluctuating ignition timing??
To be hones, i knew about the drawbacks of using a cam driven sensor for crank position. But i never knew it was a problem until now.
Did i do the right thing in selling my pfc, and going for the autronic?
Asim,....
