How is the milling process controlled? ie is it manual or are you cnc'ing it?
Would it not be easier to get the outer tooth profile wire cut and then perform the lathe operations?
You could use the key that is already used for mounting the shaft for the trigger wheel also. No need to bolt anything in. Also you then have the same reference and only that reference if you need to reassebmle the unit.
