View Poll Results: Where have you mounted your oil cooler?
Behind PASSENGER side of bumper (behind indicator on 33) 36 34.29%
In the centre by the IC and rad 43 40.95%
Behind Drivers side bumper (near the BOV's) 26 24.76%
Voters: 105. You may not vote on this poll
Old 30th December 2007, 12:29 PM   #16 (permalink)
Spearmint's Avatar
Behind the intercooler but in front of the rad.
Not sure on what my new oil temps are going to be as I now have a RIPS extended/baffled sump. Plus I replaced the take off point which had the thermostat in it and replaced it with another without one so that I could install the Defi oil temp sender. Simply put, I have no way of shutting the oil flow off to the oil cooler.
I was talking to Rob @ Rips about this who commented on the fact that he doesn't use an oil cooler on his drift car with the sump modification and his temps don't get high. Looks like I might have trouble on warming the car up, if so I'll probably make some kind of cover for it for cold days.
Also, I'm not a fan on having the oil cooler exposed. I'd rather have that inevitable stone that gets thrown up by the car in front smack into my intercooler rather than the oil cooler. Cheaper to replace your FMIC than it is to renew the bearings.
Spearmint is offline   Reply With Quote
Old 30th December 2007, 09:48 PM   #17 (permalink)
ru'
ru''s Avatar
Behind passenger indicator position, plastic 'fins' removed from indicator mount thing and holes drilled through wheel arch liner too.
Old 30th December 2007, 11:52 PM   #18 (permalink)
Alex j B's Avatar
Originally Posted by fourtoes View Post
ARC jobby slap bang in the middle of my grill!
bob
Me too, whenever the car gets back on the road!
Alex B
Old 31st December 2007, 02:39 AM   #19 (permalink)
GTR--J's Avatar
My custom install.12"x2"x2" core
GTR--J is offline   Reply With Quote
Old 23rd March 2008, 08:58 PM   #20 (permalink)
Light-R's Avatar
Send a message via MSN to Light-R
Originally Posted by Andy Hornsby View Post
Non of the above Mook!
Drivers side, in front of the rad, fixed vertically.
its where mine is fitted also.
dotn know if its the best place though. never had it anywhere else
Light-R is offline   Reply With Quote
Old 23rd March 2008, 09:17 PM   #21 (permalink)
fourtoes's Avatar
Can i change mine, after a miss hap with a stone on her maiden voyage with my ARC im now running a Greddy 10 row cooler with oil filter relocation kit, just fitted it and was tricky but its a lovely bit of kit! Quality is excellent!
bob
Old 24th March 2008, 04:27 AM   #22 (permalink)
GT-R Glenn's Avatar
GTR-J is almost exactly the same as my setup.
If you put it in the front spoiler, dont forget that the air has to get out somewhere .....
Re Robs comment, drift cars dont do lap after lap on the redline ....as long as track cars do.
If you fit something too big you can always block off 50% of the fins ...
Old 25th March 2008, 10:19 AM   #23 (permalink)
DaveV's Avatar
Me too, it works too well though, oil temp on the road never gets above 80 and highest I saw on track was 95, I have it covered most of the time
DaveV is offline   Reply With Quote
Old 26th March 2008, 08:05 AM   #24 (permalink)
R.I.P.S NZ's Avatar
By far the best all round system we've used is the heat exchanger in the bottom tank of the radiator as per the R34 Stealth Bomber, oil temps come up quicker and I've never been able to get the oil temp more than 10 deg higher than water temp, they are compact, simple and have short lines, no worries with stones etc either.
The downside is you have to buy a 90mm thick radiator at the same time and although they seem expensive initially, once actually in the car, they work out well against buying a big rad and oil cooler and installing both properly.
Rob
R34 GTR: Quickest street trim skyline in NZ, 9.7 @ 137 on 1st test pass, first meeting in the UK, 10.4 @ 144.
240z, WRH8.71 / 162 @ 2 bar, stock crank, full street trim
1972 240z, RIPS RB30, quickest/fastest Jap street car in NZ 8.71/162mph 2 bar, No NOS, street tyres.
e-mail rips@inspire.net.nz
www.ripsltd.com
Old 29th March 2008, 08:23 AM   #25 (permalink)
Adam Kindness's Avatar
Old 16th April 2008, 06:17 PM   #26 (permalink)
ru'
ru''s Avatar
Better picture of mine:
Old 24th July 2008, 02:27 AM   #27 (permalink)
Send a message via MSN to JP_Tuner
Mine's on the passenger behind the bumper. I've got a Trust 13 row with the air diversion plate. I've also got a yanack front bumper with a huge mouth right in front of the oil cooler so it lets plenty of air through.
JP_Tuner is offline   Reply With Quote
Old 24th July 2008, 05:24 AM   #28 (permalink)
Floyd's Avatar
Mine is mounted horizontal under the front offset slightly to the passenger side.
Got an alluminium scoop/shield that forces ram air through the cooler.
Floyd is offline   Reply With Quote
