| View Poll Results: Where have you mounted your oil cooler? | |||
| Behind PASSENGER side of bumper (behind indicator on 33) |
36 | 34.29% |
| In the centre by the IC and rad |
43 | 40.95% |
| Behind Drivers side bumper (near the BOV's) |
26 | 24.76% |
| Voters: 105. You may not vote on this poll | |||
ADMINISTRATOR
Aftermarket oil cooler location poll
If you have fitted an oil cooler, to a non-oil cooler equipped car, Where have you mounted it?
WANTED - TEIN FLEX for R33 GTR FOR ALL GTR FORUM RELATED ISSUES CONTACT THE ADMIN TEAM 'MOOKISTAR' OR 'MOLEMAN' SKYLINE FAQ'S! |
hmm voted infront of driver
The one infront of the Radiator doesnt get good airflow I tried it then switched the position to infront of the driver (near the Bov) u can use 1 reason also for this position as you will have better airflow to the cooler and shorter oil lines. |
ADMINISTRATOR
are you using aftermarket BOV's? do they foul the cooler at all?
I had a 16 row Mocal wedged between the intercooler and condenser but it used to run up to 110 on the track in the summer. Now switched to a 25 row and everything is about 20 degrees cooler. In the winter, almost get too much cooling. Thought about the drivers side/bumper position but if the oil filter is relocated the central cooler position is easier to get at.
Those ARC bumper-grille coolers are apparently good, but price is a bit tasty too. |
I have an ARC front mount oil cooler (replace original grill) fitted, and keep oil temp around 90C during track day, but thinking to replace it with motul either 19 rows or more behind the DRIVER's side bumper.
My mates R34 GTR track car from aboard fitted 2 HKS thermostic oil coolers on both sides of the bumper, which means there is no issue to fit it either sides. I do believe you wouldnt wish to locate the oil cooler to the PASSENGER's side as your first choice, bcos the hot oil lines would in some point pass through the radiator or intercooler, which has a very slight effect?! (just my 2p worth). Ken |
#10 (permalink) | |
Team TBD
granted we are running a massive oil cooler now on 32, but when i had the standard one located in the bottom corner of the front bumber it didnt work to its max potential as you need the correct ducting to force the air through the cooler. my 34 has cooler in bottom corner of front bumper and i could see the difference between my 32 and 34 as oil in my 34 was upto 10 degrees cooler but 34 has duct work forcing air through it.
www.abbeymotorsport.co.uk www.catdrivertraining.co.uk AS SEEN ON FIFTH GEAR ;-) www.opieoils.co.uk www.gtr-racing.co.uk RACING IS LIFE, EVERYTHING BEFORE AND AFTER IS WAITING Last edited by hockey-boy; 29th December 2007 at 10:33 AM. |
Drivers side bottom corner of the bumper on my r33 gtr !! Ive a trust front bumper on mine tho , the cooler itself is ducted from the vent on the bumper. Runs good and cold.
#12 (permalink) | |
