i fitted tomei sump baffle 2 days ago very straight forward although you may need half shaft oil seal after doing the job as you have to pull out the shaft and shaft tube in order drill bigger holes in the oil supply jets from top of sump to bottom of sump seal doesnt come out easy so you will make sXXt of it
