Old 10th July 2006, 10:10 PM   #1 (permalink)
Unhappy Strange Fuel fuse / engine running question
Hi All,
Posting on behalf of a friend who has a R34. He has recently being doing some cosmetic and audio work on the car and its started to behave a bit strangly.
Out of the blue the car would not start. The engine was trying to turn over but it would not fire. It was clear there was a problem with fuel as when you turned the key you could not hear the fuel pump priming.
After a lot of looking around the car and scratching our heads we found that a 15 amp fuse appeared to be missing from the panel under the steering wheel which we thought was on the fuel circuit.
By placing a fuse in, the car started perfectly and run BUT it would continue to run even after pulling the keys out the ignition.
Upon removal of the fuse the engine stopped and then the car appeared to work fine starting and stopping as usual.
Then again yesterday for no apparent reason it would not start. By turning on the ignition. Placing the fuse in and then pulling it out again was enough to trigger the fuel pump and again get everything working as normal.
Does anyone have any idea what could be causing this?
No work was being done around the fuse panel etc so not sure why it just suddenly started.
Thanks in advance
Rob
Rob_Quads is offline   Reply With Quote
Old 14th November 2008, 10:05 PM   #2 (permalink)
hi mate my car is r34 gtr its doing exactly the same thing but it started after hours of struggling i stripped the fuse panel out and noticed the panel on the back where 3 relays are blue coloured 1 holder was broken also my mfd switches on and off
i now need a new fuse panel i only just bought the car and now this but hey im a big fon of r34 gtrs so not put off it lol
il keep you informed as and when i find the fuse panel and refit it only then il know for certain if its right as its not drivable atm
n600hks is offline   Reply With Quote
Old 15th November 2008, 12:21 AM   #3 (permalink)
frostmotorsport's Avatar
does the car have a turbo timer? maybe that's wired in wrong, or playing up or something. the symptoms you describe are very unusual!! What happens if you put the fuse in, fire it up then pull the fuse while it's running?
