4wd problem
I have 4wd light to turns on once in a while. I have a code 18. I've checked the connectors to the pressure switch and they are all clean. I've done all the continuity checks and the harness tests all fine.
Do I just have a bad ETS hydraulic unit? How much do these run? Anything else I should check? |
If there is an abs fault or even low fluid it can bring that light up as abs and 4wd activate the same light.
R34 GTR: Quickest full street trim skyline in NZ, 9.7 @ 137 on 1st test pass, first meeting in the UK, 10.4 @ 144. RIPS 240z, WRH8.36 / 163 @ 1.9 bar, stock crank, stock block, petrol RIPS 240z, RIPS RB30, quickest/fastest Jap street car in NZ 8.36/163mph 1.9 bar. NZs quickest Pro Import on petrol. RB engine building, alloy and stainless fabrication, affordable skyline tuning and high capacity repowers, worldwide shipping arranged. e-mail rips@inspire.net.nz www.ripsracing.com
Hey there
i have exactly the same fault on mine..........my specialist assures me that it's the valve acting up, not earthing or any other intermittent thing. About £200 to replace with a secondhand unit. If you can find one of course. I bet it does it more when it rains!!..........and if you do a lot of short journeys in one day...........that's normally what triggers mine off. OK in the dry, not much fun in the wet though!!! Hope that helps. RR. |
