Old 3rd November 2002, 10:43 PM   #1 (permalink)
Harry's Avatar
Send a message via ICQ to Harry
Question Standard Suspension
Can anyone tell me what the spring rate is for the suspension on an R33 V-Spec? Wanting to benchmark against upgraded kit.
Thanks
Harry is online now   Reply With Quote
Old 4th November 2002, 12:43 AM   #2 (permalink)
Banned
Mycroft's Avatar
Send a message via ICQ to Mycroft Send a message via AIM to Mycroft Send a message via Yahoo to Mycroft
Interested also, as I can then make a mathematical model of the whole thing and play around with my nice 3d suspension program again.
Old 4th November 2002, 02:10 AM   #3 (permalink)
DCD
DCD's Avatar
Send a message via MSN to DCD
4.0kg/mm front & 5.0 kg/mm rear
Old 4th November 2002, 09:32 AM   #4 (permalink)
Harry's Avatar
DCD - perfect, thanks
Mycroft - what outputs will your software give you?
Old 4th November 2002, 10:00 AM   #5 (permalink)
Banned
Mycroft's Avatar
Base resonance, load point readings, stresses, quite a bit really.
Are your springs not progressively rated?
Old 4th November 2002, 10:02 AM   #6 (permalink)
DCD
DCD's Avatar
Mycroft....do you need any info on the damper specs?
Old 4th November 2002, 10:14 AM   #7 (permalink)
Banned
Mycroft's Avatar
Any info helps, but I tend to use 'baseline figures' then play around a bit.
Old 4th November 2002, 10:22 AM   #8 (permalink)
Banned
Mycroft's Avatar
My quick play around gives me 70lb/in to 105lb/in for the front, 55lb/in to 95lb/in for the rear, this is using standard(ish) shockers but with differing bounce and rebound rate there isn't a huge variation, the sprung/unsprung balance does though, by quite a large amount.
More info please.
Old 4th November 2002, 10:29 AM   #9 (permalink)
Banned
Mycroft's Avatar
1kg/mm equals (approx) 11.5lb/in.
Old 4th November 2002, 10:43 AM   #10 (permalink)
DCD
DCD's Avatar
Dampers: (kg•0.3m/s)
Front: Bump 275, Rebound 85
Rear: Bump 175, Rebound 67
Stabilizer: (ø)
Front: ø 22.2mm
Rear: ø 26.5mm
What about alignment? Would that be of any use?
Old 4th November 2002, 10:57 AM   #11 (permalink)
Banned
Mycroft's Avatar
I have the 'stick diagram that Nismo use for their computations so I'll play around with that for a while but, the normal running angles would be nice, sorry to keep asking for more stuff but more info=better (more consistent) results.
Old 4th November 2002, 11:02 AM   #12 (permalink)
Banned
Mycroft's Avatar
I must say that at present using dual rates appear to give better resonances overall, I especially like the fact that at 3/4 stroke (hard cornering) the frequency of the loaded assembly stays at 2.6cps at the front, that is very stable, the single rate gives 3.8cps, at the front lower frequency=better handling.
Old 4th November 2002, 12:05 PM   #13 (permalink)
DCD
DCD's Avatar
OK, here it is:
-Front-
Camber: -0º50' (+/-45')
Caster: 3º55' (+/-45')
Toe in: in 2~0 mm
King pin: 15º20' (+/-45') ««-- No idea what this is
-Rear-
Camber: -1º15' (+/-30')
Toe in: 0~in5.2 mm
Old 4th November 2002, 03:13 PM   #14 (permalink)
Banned
Mycroft's Avatar
I have assumed that you have Nolothane P5 grade (NP5) bushes (they are standard on the bigger Nissans and Toyotas.
If you have Polypropylene type (PP3) the characteristics will be slightly inferior all round, the large number of links in the design means that Kinematics becomes a serious issue and are better controlled by Nolothane due to its better inherent 'Tension Reparte' and Hysteresis.
Old 6th November 2002, 10:28 PM   #15 (permalink)
Banned
Mycroft's Avatar
Harry, how you doin'?
Where ya' goin with this?
Are you certain that the springs ARE the issue not the Bushes!
As a general rule, upgrading the Bushes does more good than upgrading springs with standard bushes, go to Nolothane 'Red' (very hard)or even blue (hard) would be a definite improvement.
