Go Back   GT-R Register - Official Nissan Skyline and GTR Owners Club forum > For Sale & Wanted > Private: For Sale - CARS ONLY > Nissan R34 cars
Old 12th July 2006, 10:10 AM   #1 (permalink)
NITO's Avatar
Cars owned: V-Spec II Nür
Nissan Skyline R34 GTR V-Spec II Nur
BNR34 V-Spec II Nur Edition
Hi everyone,
I’m selling my Nur after nearly three years with it. I bought it from our illustrious webmaster Cem (Blowdog) in December 2003.
It was originally sourced and supplied by Zele international and specced by Nismo. Prospec brought the car to the UK with approx 13,000kms on the clock. It was then converted into miles and has full service history with Abbey Motorsport and RB Motorsport. The car currently has covered approximately 25,000 miles.
Since owning it I have spent a fortune on it. The cosmetics etc were already perfect, so I concentrated on extracting more power while keeping it as a daily driver. It has a brand new Top Secret RB28 engine (supplied by Prospec Motorsport) fitted approx 3,000 miles along with the rest of the spec which I will list below. All parts are new and the car currently pushes out 650bhp and over 500lbs/ft torque. The engine and fuel system are rated to 900ps and the car has the remainder of the kit necessary to safely run this with much time and money spent on cooling. To run mega power all you would need to do is fit a larger turbo (T51R for example) and remap. As a road car it is extremely quick and I don’t think there are many people who would want more power, response and low down torque than it already has.
Details as follows;
2002 Final Production run 1 of 750 V-spec II Nurs
Finished in Sparkling Silver
1 of only 4 in the UK (only one other in this colour.)
25,000 miles (3,000 miles on new spec only)
2 UK owners (myself and Cem)
650bhp+ / 507lbs/ft
Spec below:
Nissan Skyline GTR R34 2002 V-Spec II Nur
Engine - (Mapped to 8.5k rpm redline for reliability)
Top Secret Built HKS Step 2 RB28 Bare Engine (Rated to 900ps and 9k rpm)
Top Secret Cylinder Head Ported/Polished
Top Secret Studs
Top Secret Edition HKS Cam Pulleys
Top Secret Painted Rocker Covers
HKS Forged Pistons
HKS Steel Connecting Rods
HKS Steel Crankshaft (Step 2)
HKS 272in Step 2 Camshafts 10.2mm Lift (Trust Valve Springs)
HKS 272ex Step 2 Camshaft 10.2mm Lift (Trust Valve Springs)
HKS 1.2mm Metal Gasket
HKS Metal Intake Manifold/Throttle Body Gaskets
HKS Exhaust Manifold Headers
HKS GT II External Wastegate
HKS Wastegate Return pipe
HKS T04Z Turbocharger Conversion
HKS Kansai Carbon Fibre Spark Plug/Cam Pulley Cover
Trust Valve Springs
Trust Timing Belt
Nismo N1 Engine Block
Nismo Engine Mount set (3)
NGK Racing 8's Recessed Spark Plugs R7434-8
Aeroquip Pro Gold Teflon Lined Nomex Oil Catch Hoses
Aeroquip Pro Gold Rocker Cover Fittings
Intake and Exhaust System
HKS Super Power Flow Intake
HKS Polished Induction Pipe
HKS Polished Intercooler Entry Pipe
HKS Frontpipe 76mm
HKS Ti Muffler 102mm
ARC Titanium Straight Catalyst Replacement pipe 80mm
Nismo Balanced Intake Collector Plenum
Trust Greddy Polished Intake Pipe
Fuel System
HKS In Tank Fuel Pump
HKS 1000cc Injectors x6
HKS 11.0mm Fuel Rail
Aeromotive A1000 Fuel Pump p/n 11101
Aeromotive 10 micron post pump filter p/n 12301
Aeroquip Pro Gold Teflon Lined Nomex Braided Hose Feed (-12/ -10/ 2x -6)
Aeroquip Pro Gold Teflon Lined Nomex Braided Hose -6 Return Line
Abbey Motorsport Alloy "Tank Top Mount Plate" with Bulkhead Fittings
Abbey Motorsport Military Spec Fuel Pump Connector
Abbey Motorsport External Swirl Pot
Abbey Motorsport T-Piece Distribution Mini Swirl Pot
SARD Adjustable Fuel Pressure Regulator
Oil and Water Cooling System
HKS GT Bar and Plate Intercooler
HKS Thermostatically controlled Oil Cooling System
Trust High Capacity Oil Pump
Trust Large Capacity Baffled Sump Extension/Extended Oil Pickup
Trust Greddy Oil Filter Relocation Kit
Trust Greddy Front Diff Casing
ARC SMC55 Side Flow Super Micro Conditioner Water Radiator
ARC Air Remover Set
ARC Water Swirl Pot
Border Racing Oil Catch Tank
Nismo N1 Water Pump
SARD 68 Deg c Thermostat
Samco Silicone Lower Water Radiator Hose
Management and Electronics
HKS EVC V Electronic Boost Controller
HKS A/F Knock Amp with O2 Wideband/Knock Feedback
HKS F-Con V Pro Fuel & Ignition Timing Computer
HKS Mass Air Pressure Sensor 0-4Kpa
HKS BNR34 F-Con Wiring Loom
HKS Air Temp Sensor Harness
NTK Nissan Wideband Lambda Sensor
Defi VSD Concept
Defi BF Boost Meter
Defi BF Fuel Pressure Meter with differential pressure
Defi BF EGT
Defi Control Unit II
Transmission
Nismo G-Max Lightened Balanced Flywheel
Nismo G-Max Twin Plate Clutch (enlarged Spline version)
Nismo Getrag Large Diameter Input Shaft
Nissan Getrag 6 Speed Transmission
Chassis
Nismo G-Attack S-Tune HA Suspension System
Nismo LMGT4 Limited Alloys / Falken FK451's 265/35/18 Tyres
Nismo Titanium Strut Tower
Nismo Braided Steel Brake Hoses
Nissan N1 Brembo Twin Pot Caliper Rear
Nissan R33 Front Lower Wishbone Set
Sunline Racing Adjustable Tension Rod Set
AP Racing 6 Piston 362mm Brake Conversion Front
Ferodo DS2500 Brake Pads Front & Rear
Bodywork & Dress Up
Nismo Z -Tune Carbon Fibre Vented Bonnet with Forced Air Intake
Nismo Front Bumper
Nismo Side Skirts
Nismo Rear Skirts
Nismo Carbon Fibre Rear Spoiler Blade
Nismo Carbon Fibre Rear Diffuser
Nismo Style Carbon Fibre Front Splitter
Nismo Clear Repeaters
Nismo Oil Cap
Nismo Fuel Cap
Mines Carbon Fibre Aero Mirrors
Garage Defend Carbon Fibre Cooling Panel
Robsons Carbon Fibre Injector Electrics Housing
Augment Carbon Fibre Bonnet Damper Struts
ARC Water Radiator cap
ARC Air Remover pressure caps
Rays Air Valve Caps
Chrome Fuse Box Cover with Top Secret/HKS Logo
Interior
Nismo Steering Boss
Nismo Willans Race Harnesses x2
Nismo Titanium GT Gearknob
Nismo MFD2 Multi Function Display
Nismo Race Shut off Cigarette Lighter
Nur Interior (Black)
GTR Emblem Carpet Mats
Custom HKS A/F Knock Amp/EVC V Boost Controller Housing
Trust Greddy Twin A-Pillar Pod
Momo Race Steering Wheel
The car also has a Cat1 Alarm/Immobiliser.
Reason for sale is that I now have two children and I simply don’t have the time to play with the car. It’s not my commuter car and it’s not an ideal family day out car which means it doesn’t get much use. If I keep it I’ll ending up spending even more on it which I’m keen to avoid as I can no longer justify it after what has already been spent.
Price wise I’m looking for £68k as specified above. It stands me in at a lot more than this and anyone who has started tuning their car knows how expensive it is to do properly. Nothing has been skimped on. The car hasn’t been ragged to death and this spec hasn’t seen any miles in anger, half of it has been spent running in and mapping. It is totally fresh and should give many trouble free miles. It has been built as a fast road car and is still very comfortable and absorbs bumps etc and puts down the power extremely well. I live on twisty country roads and it travels beautifully across these. It is a very rare car in its own right (it’s the last production run of BNR34’s and the last of the RB26 engined GTR’s) and now has the power to match its looks.
Power can be reduced down to around 500bhp with the boost controller switched off running 0.8 bar, or 570bhp at 1.2bar on low boost. High boost is set to 1.7-1.8bar for 650bhp and has been mapped by Abbey Motorsport on their Dynapack. Quoted bhp figures are hub figures +70 to calculate at the flywheel. Power runs were done in hot weather so should yield even more in the winter.
Condition is immaculate. The most recent pics are below.
Right click and save as for old movie which German TV made of this car;
http://www.lyonsannoot.co.uk/nito/Nu...ec%20movie.asf
Viewing by appointment only, serious enquiries please, for more info please pm me in the first instance or mail to nito at nitosport.co.uk
Passenger seat test drives only to serious parties
(unless satisfactory demonstration of the following);
-Insurance proof, Driving License and means of payment.
There are a couple of things that need tidying up before it goes (new windscreen etc) and these will be done in the next couple of weeks. Obviously the sale excludes the private plate. It is taxed for another 11 months and MOT is due in January '07.
Thanks
Nito
Old 12th July 2006, 10:11 AM   #2 (permalink)
Luffy's Avatar
Cars owned: Reinik Powered R33 GTR
What a CAR.
sorry to see you are selling Nito, free bump although i doubt you will need it.
Luffy is offline   Reply With Quote
Old 12th July 2006, 10:50 AM   #3 (permalink)
JapFreak786's Avatar
good luck selling the car
*off to rob a few banks
Old 12th July 2006, 11:04 AM   #4 (permalink)
Cars owned: was lotus exige now R33 Le Mans GTR
you know it really annoys me when people sell things like this when i have no money! oooowwwgghh suits you sah! suits you!
koopa is offline   Reply With Quote
Old 12th July 2006, 12:15 PM   #5 (permalink)
AJFleming's Avatar
Cars owned: 620BHP Track prepped FD3S RX7
If I was gonna buy any GTR in the UK it would be this one R34 has less Kudos for me as its the one all the chavs know but this car is just right. Love it, good luck mate, ill be ringing you if my numbers come up this week
AJFleming is offline   Reply With Quote
Old 12th July 2006, 01:11 PM   #6 (permalink)
Just stunning, good luck with the sale matey
Mike
kirbz is offline   Reply With Quote
Old 12th July 2006, 01:16 PM   #7 (permalink)
Alecci's Avatar
Cars owned: '99 R34 GTR
Colour me amazed! That's simply an incredible machine! That spec list basically made me afraid of the dark...
For the first time in my life I'll buy lottery tickets today, let's hope for beginner's luck.
I reluctantly wish you good luck selling the car, I hope you change your mind and keep it until I can buy it some time in the distant future.
And truly sorry for OT, I just couldn't help myself...
Alecci is offline   Reply With Quote
Old 12th July 2006, 02:10 PM   #8 (permalink)
Wow wow wow wow wow!!!
BUG4LIFE is offline   Reply With Quote
Old 12th July 2006, 03:54 PM   #9 (permalink)
cky
cky's Avatar
Cars owned: Nissan Skyline GTT
Send a message via MSN to cky
Someone give me a loan for about 68k
Very very nice car, the first time i've ever seen a Nur being sold and now the first time I'm buying 20 lotto tickets
If I see this car going about Im and then after it
cky is offline   Reply With Quote
Old 13th July 2006, 09:14 AM   #10 (permalink)
deef's Avatar
Cars owned: gtr-34
Send a message via MSN to deef
Lovely car, sorry to hear it has to go....
P.S What a vid, wish I could understand german
deef is offline   Reply With Quote
Old 13th July 2006, 09:52 AM   #11 (permalink)
rb26's Avatar
Cars owned: R34 Gtr V-spec
Hi Nito,
Like i said at the Abbey aniversary.
This is the best looking, cleanest Gtr i have ever seen.
And that overall spec!!
I don't know what else to say!!
I hope she goes to a good home.
Regards,
Terje.
rb26 is online now   Reply With Quote
Old 13th July 2006, 01:23 PM   #12 (permalink)
Pharoahe's Avatar
Cars owned: Skyline
One incredible machine, truly awesome.
free bump
Pharoahe is offline   Reply With Quote
Old 13th July 2006, 02:38 PM   #13 (permalink)
GTROC 011
matt j's Avatar
Cars owned: '99 UK R33 GT-R V-Spec
Send a message via AIM to matt j Send a message via MSN to matt j
Nito,
It is truly an amazing car and spec.
I hope the new owner looks after it as much as you have.
For anyone who's interested, I can honestly say that the spec is awesome on the road - as mine is the same
Good luck with the sale Nito.
Matt.
Rest in Peace Dad
Old 13th July 2006, 02:51 PM   #14 (permalink)
Administrator
Blow Dog's Avatar
Cars owned: Porsche 997 GT3
Send a message via ICQ to Blow Dog
I was so close to deleting this thread.
Nito, if you look closely at your receipt, you signed a contract -
Section 34, Clause 3, Paragraph 6:
You are not allowed to sell this car. Ever.
So I'm sorry to say you cannot sell this. Makes me so sad as this car was soooooo much to me. If anyone is interested in more pictures, I have 1000's.
Please make sure any potential buyers promise to not mess this car up, because if this car so much as goes NEAR a neon light, I will be bulldozing their home. Honestly - filter every single person. Anyone with a baseball cap, don't answer your door. In fact, give MY phone number for enquiries.
Cem
Forum Webmaster
Relaunched and back with verve
blowdog.com | musings of a 35 year young child.
Blow Dog is offline   Reply With Quote
Old 13th July 2006, 03:21 PM   #15 (permalink)
bkvj's Avatar
dude, this car is pretty close to me i think! where in kent are you? im going to find you and convice you not selling this car!
bkvj is offline   Reply With Quote
© 2001-2009 Cem Kocu
