Fuel Pump Earth
I have an R32 GTR with a faulty fuel pump earth. Im guessing the earth wire runing into the top of the petrol tank has broken down somewhere.
My question is can I cut this wire and just run a new earth to somewhere in the back of the car without any problems? |
Probably a faulty fuel pump ECU (located behind R/R passenger armrest trim panel).
I had the same problem on my 32 GTR so rather than replace a part I dont think the car needed (it regulates fuel pump voltage hi/low) I just bypassed it and gave my fuel pump battery voltage ![]() I could well be wrong though.........a wire could break anywhere I guess. Good luck ![]() |
#4 (permalink) | |
Does that fuel pump ecu operate on the live or the earth? Would have thought it would be the live.
Elitetech Automotive
I had intermitant fuel pump problems on my old GTI-R........Problem got worse and worse until one day it completely failed.
I believe that the uprated pump (from a GTR) was drawing a larger current.......this resulted in one of the loom connectors (under the back seat) had got too hot and melted. i chopped both looms and rejoined them and it was fine. Car was sold months later and thankfully the concern hadn't moved to the next connector! Never know, could be similar problem! Ian
+10 extra bhp for £55.... Get your baffled TWIN TURBO pipe now from GTR.co.uk Shop My project |
#6 (permalink) | |
When the fuel pump ECU faults it can prevent the pump from getting maximum amperage or possibly voltage - thereby stopping it from delivering its required output?? (apologies my electrical skills are limited) End result is your fuel pump is stuck in "low fuel delivery mode" when its suppossed to be in "high delivery mode" - like my car was. I'm not sure what the fuel pump ECU uses to switch between the 2 but it could quite possibly be rpm and or air flow meter voltage. My car was seriously lacking power about 4500rpm and when I put an AF meter up the exhaust was horrified to find it was running a mixture of 16.2:1 on full boost!! Due to my squish areas being removed from my cylinder head my engine wasnt detonating but EGT's were through the roof I was very lucky that stupid ECU didnt cost me my motor. I suggest any older R32 owners should bypass it. Wouldnt want it to play up when your flat out in 5th gear. Melted pistons here I come :P |
http://www.stealth316.com/2-fuelpumpvoltage.htm useful info
