zeroreality
Cars owned: GTS-T
A little info for SVA
Hi Guys,
The SVA form needs the following info that I don't have (for R33 GTS) Maximum Road Speed : Maximum Power Engine Speed : (speed in rpm, at which the engine produces maximum power) Can anyone help with this? Getting a little excited now, I pick the car up next Saturday. Phil Oh yea and is ABS fitted as STD?
Rick
Cars owned: R32 GT-R, Soarer,
Hi Phil when you go for the SVA make sure your tyres have an "E" mark on them, even good Japanese tyres will fail because of this.
If you need any help mail me Rick ![]()
Moschops
is ecstatic to have his Skyline on the road!
Cars owned: White '96 R33 GTS25t, K11 Micra 1.0
ABS I think was optional - I don't have it on my GTS25t.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. abandoned.. :( ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. very much alive! |
JasonO
is absent.
ABS was an option, but the fuse box will have a couple of fuses in the ABS position even if the ABS is not fitted (I've yet to figure out what they do).
It is possible to tell if your car has ABS as standard from the chassis number. email me.
zeroreality
Cars owned: GTS-T
Thx
I've posted the SVA docs now, so it's just a matter of waiting.
Matt, did your's pass the SVA with the turbotimer fitted, I've heard that will fail them. I'll let you know about the tyres, if they're not "E" does anyone have a spare set (tyre's % wheels) that I could borrow for the SVA ( the car will be trailered there and back so the tyre's won't be used... I've built up this list of things to do pre-SVA if anyone can think of anything else, let me know... Fuel neck restrictor KMH - KPH electronic converter Rear fogs converting innet brakes to fogs & adding switch 130 MPH rated tyres ("E"?) cable ties on all uner bonned cableing every 12" (remove TTimer...) Thanks Guy's.
BikerBob
Cars owned: R33GTST
Your welcome to borrow my standard wheels with good tyres (Need them back quick though as they're my winter wheels!). I'm in Lancs...any use to you?
