Old 18th July 2006, 12:44 AM   #1 (permalink)
jas3113's Avatar
Stock spool time on a R34 and intercooler overkill?
Since there are not much GTR's in the US I wanted to see if you guys can help.
My R33 has a R34 motor swap on it, ECU and wiring was swapped out also. I've had the car for about 2 months and I feel the car is a pig, (sorry to say), I've had Eclipses (2 door Evo's) with intake and exhaust and the car pulls much harder then the R33. Full boost doesn't seem to come on until 3600 rpm, the car seems to run rich (I think it's due to the HKS SSQ's)
Current mods on the car is:
R34 Swap (3000 miles on the motor)
HKS Down pipe
ARC Ti 100mm exhaust
Mine's intake
ARC Catch can
HKS SSQ
There are no boost controller and everything else is stock.
Is slow spool normal on the the R34 motors?
Lastly I got a good deal on a Greddy R-SPL HG, 302x710x165, would you guys recommend to put this on with the following set up (see below) or wait the my next setup a 2.8 (going in about 1 1/2 months from now)
HKS GT2530's
HKS 272's
Nismo drop in pump
720 cc injectors
HKS or Tomei Fuel rail
SX FPR
HKS Hard pipes
ATTKD Ti extension housing
ATTKD Ti Down pipes
AEM EMS running on Map
Thanks in advance guys!
John
R33 Nissan Skyline GTR V-Spec LM Ltd- Angelina
R33 Nissan Skyline GTR - Jennifer
R33 Nissan Skyline GTR V-Spec- Kathy
FYI I look much better than Brad Pitt
Sponsored by-LM24,Inc www.LM24.net
Special thanks to- RB Motoring www.RBMotoring.com and JDMSpeedShop.com
GTROC Member in the US
jas3113 is offline   Reply With Quote
Old 18th July 2006, 02:02 AM   #2 (permalink)
That sounds about right John. Std GTRs are pretty crappy. They need at least 400hp to be interesting. The Trust intercooler is maybe a little OTT but should be fine. Once the 2530s etc are fitted you will be a lot happier. The fuel rail isn't needed and is just cosmetic.
COSSYCam is offline   Reply With Quote
Old 18th July 2006, 02:06 AM   #3 (permalink)
jas3113's Avatar
Thanks Cossy, I knew they GTR's are alittle on the slow side, but I didn't realize it was by that much . Thanks I get to save some money on not buying a rail
Regards,
John
Old 18th July 2006, 02:12 AM   #4 (permalink)
Thumbs up
Regards,
John
I'd go with a Nismo or Sard FPR as well over an SX
Old 18th July 2006, 07:22 AM   #5 (permalink)
huracan0613's Avatar
HKS Down pipe
Mine's intake
ARC Catch can
HKS SSQ
HKS GT2530's
HKS 272's
Nismo drop in pump
720 cc injectors
SX FPR
HKS Hard pipes
ATTKD Ti Down pipes
John
if you're not going to upgrade the fuel rail and keep the stock one, your only option will be the 740cc nismo injectors. the thing about the stock fuel rail is that is front fed and the front cylinders get most of the fuel while the last 2 are starved, even if you have fpr. it's best in my opinion to spend some 2 or 3 hundred bucks in one.
huracan0613 is offline   Reply With Quote
Old 18th July 2006, 07:09 PM   #6 (permalink)
Felt the same way about my R34 when i first picked it up, took forever to spool up and just wasnt nice to drive to be honest, thought my old wrx was alot quicker, but once the downpipes/decat pipe and tuning took place it's a whole new ball game 400 + bhp and very responsive, loving every minute of it
z3gga is offline   Reply With Quote
Old 18th July 2006, 07:27 PM   #7 (permalink)
sfgtr's Avatar
r34 gtr turbos
sorry for the newby question but i'm looking at buying a set,are all r34 gtr turbos steel internals and if so what sort of boost can they handle. thanks
cannonball 8000 the best 4days of my life.
sfgtr is offline   Reply With Quote
Old 19th July 2006, 02:37 AM   #8 (permalink)
jas3113's Avatar
I might just splurge on the rail. So I guss I'm not imagining on the lag on the turbo.
I'll be in at least 450 sometime next week
John
Old 19th July 2006, 07:03 AM   #9 (permalink)
I'm running 1000cc Sard injectors in a std rail no problem and a Nismo FPR.
Old 22nd July 2006, 08:33 PM   #10 (permalink)
jas3113's Avatar
Thanks Cossy. I just realized I have one for the 2.8 that being built.
Apparently, the rear turbo outlet to intercooler was missing one bolt holding it in. She feels like a champ now . Too bad, the turbo's are coming out in a couple of weeks
Thanks guys.
John
