GTR Base timing, idle stumble please help
1989 R32 GTR Power FC (base map/settings) 800 cc sard injectors.
I am wraping up a two year buildup, fuel pressure is not adj yet. I have been trying to adjust the timing of my gtr after a buildup. Idle is eratic so i unplugged the acc and adusted the idle screw to get the idle roughly around 950 + or - 10 rpm. then i hook up a Innova timing light to the 1st cyl loop by the ignition module at back of cam cover. it looks as if the timing is at 45-50 deg btdc. what am i doing wrong. i will try to run a spark lead from the coil to plug and attempt that way. any other ideas. duz PFC make any changes to takeing a base timing reading? also between full LH and RH actuation of the CAS it only adjusts between 30 deg btdc and 50 deg btdc on crank. I have 800cc sard injectors, should i expect to have a slight stumble at idle with these injectors. (Base fuel press no adj yet, timing not spot on but not off by much either, PFC running on base map). stumble is not present off idle |
