Plain bearing need to run high oil pressure as the shafts are designed to run on an oil film, Roller like less volume as the oil is just to lubricate the balls in the bearing. High volume of oil can cause the balls to skate and be damaged.
Andy,
I have run up to 9bar pressure on my non BB Kai, worn seals? Rob
599hp R35 Gtr www.trracing.co.uk T62 Going back on for track WTF!! :D Addicted to Snett!! Roll on the 24th of jan £99 rocks! |
I don't think the seals are at fault. It was fine on my old engine with the std oil pump.
It's interesting that you say you ran with 9 bar ok. I would have thought my pressure wouldn't have exceeded the max designed pressue. Maybe thay were damaged when the turbo was re-balanced. |
