Hey all ...
I've been reading the forums but never posted I'm from the gulf ... more specifically BAHRAIN ... I got a 97 V-spec R33, I've been owning this car for 2 yrs and I sure love it Anyways, When I first bought the car, Mis shifted and the oil pump gave up, Had the engine replaced with another one ... It looked stock and stock turbo housing ... For the past 1.5 yr the car has been boosting 1 bar in the summer and 1.3 bar in the winter without a boost controller what so ever ... Recently, I have connected my apexi avc-r and boosted the car till 1.7 bar with no problems on stock injectors, I know I'm way over the inj's duty cycle but tried it few times only ... I have been boosting and racing the car at 1.5 bar ..where the inj duty cycle is 99.5 % and have no problems ! I listen for detonation, nothing ...seems smooth and pulls like hell ... My question is, Is it possible that my turbos are upgraded n1 or something ? Cause stockers wouldn't last much over 1 bar ..am I right ? Thanx |
Stock turbo's are on brink of destruction at levels around 1.2bar, imagine them to be uprated.
In fact I would anticipate that the whole engine, ecu and fuel system is uprated if you've ran it at 1.7bar.. Some kind of limited edition kryptonite pistons installed from Nissan if everything is standard. With the temps in the gulf....I can't believe you haven't destroyed your engine. |
To be honest, The turbos looked stock when the engine was out ... ! the tiny t28s ... The car is usually out at night ...But the temp is still high though ..around 30 and a 100% humidity Killed a Manual c6 with bolt-ons and cam last night at 1.5 bar ... Btw ... We got soo many fast GT-Rs over here, mostly in the 9s and one in the 8s |
#6 (permalink) | ||
1.7 bar on stock injectors! And on stock turbos! Ceramic stock turbos on the R33 should be kept at 1.0bar or below. Even with steel turbines, anymore than 1.3bar is just blowing hot air.
Stock injectors are 440cc and they should max out before you reach 1.3 bar. Have you had it dyno'd because I'm struggling to make any sense of this physics-defying feat? |
#8 (permalink) | |
http://homepage.ntlworld.com/tbroom/Turbos.htm So you could theoretically run that boost with T28s but you would need uprated injectors and air-flow meters and (probaly) ECU too. Not sure about fuel pump upgrade as well. I'm guessing your injectors are 600cc or around that. Basically your car must be less standard than you think and running a 99.5% duty cycle has no long term prosperity. Last edited by R33_GTS-t; 15th August 2006 at 04:30 PM. |
#9 (permalink) | |
Bugger where were they at TOTB Arabia when it was held then ?
Year 4 of the 5 year journey starts March 09 ........ Europes 1st Ever 7 sec skyline 7.7537s @ 175.64mph backed up Europes Fastest Jap car in 2008 - www.projectgtst.com |
#10 (permalink) | |
I agree that it's not wise and doing it on stock turbos is just plain madness. |
