Old 9th August 2006, 08:09 PM   #1 (permalink)
NigelR32's Avatar
EGT Removal???
I've just fitted a decat and Downpipes to my R32 GTR, and my boost has dropped from .9 bar to .7??? I disconnected the EGT connector under the passenger seat.
I've also fitted some known good standard dump valves to try and cure the misfiring issue I've been getting.
The car no longer misfires (Fingers Crossed), but only reaches .7 bar max boost????
Any ideas???
Nigel...........GTROC Member
Now on '32GTR No.3
NigelR32 is offline   Reply With Quote
Old 9th August 2006, 09:48 PM   #2 (permalink)
tweenierob's Avatar
The sensor is just a CAT ON FIRE sensor and is only used to light the warning on the dash, if you disconnect it all that will happen is the light wont come on.
Rob
599hp R35 Gtr www.trracing.co.uk
T62 Going back on for track WTF!! :D
Addicted to Snett!! Roll on the 24th of jan £99 rocks!
Old 10th August 2006, 12:11 PM   #3 (permalink)
Hugh Keir's Avatar
You have changed the ehaust back pressure by fitting the de-cat.
You will need to modify your boost control system to get your boost back
You should really involve a tuner to make sure you dont push your engine too hard with the wrong air / fuel ratio.
Old 10th August 2006, 04:14 PM   #4 (permalink)
SIHethers's Avatar
Try reconnecting the cat sensor, just in case it has gone into "limp-home" mode as a result of removal. Not sure if this exists on Skylines but could explain actuator boost if it does.
Hugh, would lower backpressure not result in overboost and unstable boost rather than limited boost?
SIHethers is offline   Reply With Quote
