My R33 Spec V is not AWD...
Yep... when I had it on the AWD-DYNO the front wheels were NOT
spining.... Yes the drive shafts are hooked up There is fluid in them The A-LSD light is on fixed.... what should I check first or is there a list of things to check? Thanks guys... |
Fluid / Fuse/connectors.
ECU Diagnostic.
___________________ ..+ +.. HQ is Now Closed Note for Marketing Agencies - McDONALD'S Make your brown carrier bags green in colour so they blend in with the countryside after they've been thrown out of car windows. |
#9 (permalink) | ||
Sorry to hijack - I wouldn't mind a pdf copy of the engine manual - any chance? (pretty please)
http://www.youtube.com/watch?v=25kYw29RnCA |
The computer in the truck throws a light. Count the number, tell us what it is. Can figure it out from there.
R33 has backup power supply for the AWD. Even with the ALSD light on, it will still partially power the front wheels. If its not spinning the front wheels, perhaps the Attesa system needs to be bleed - working on writing some things up , I get a lot of questions about this kind of stuff. - http://tyndago.googlepages.com/gt-rbleedingattesasystem. Or the clutches in the clutch pack may be damaged. |
