Old 15th August 2006, 10:58 PM   #1 (permalink)
Nocturnal's Avatar
What is Vband???
I have done load of searching, and I still can't find it. Everyone seems to know what it is except me.
What is VBAND??? I see all kind of adaptor for it. What is it? And is it any better?
WideBody BNR32: Winner of the 2007 Cubism Award!!!
Banzai October 2007 Feature Car / MaxPower April 2008 Feature Car
For Magazine Feature, Wallpapers, Videos, and more...CLICK HERE!!!
Nocturnal is offline   Reply With Quote
Old 15th August 2006, 11:34 PM   #2 (permalink)
toddrb30gtr's Avatar
VBAND is a type of fitting, there are many different types and versions,,,,,,,, it is a circular fitting with 2 parts that lock together...each part forming half the v shape and a clamp that the more you tighten the more pressure it puts on the sealing surfaces......... hope that helps, im shite on descriptions!!!!!
toddrb30gtr is offline   Reply With Quote
Old 15th August 2006, 11:40 PM   #3 (permalink)
Andy W's Avatar
a posh name for a clamp
bovered me, do i look bovered, bovered , no
AA join here
Andy W is offline   Reply With Quote
Old 16th August 2006, 12:17 AM   #4 (permalink)
BBD
BBD's Avatar
Send a message via MSN to BBD
easier to work with
BBD is offline   Reply With Quote
Old 16th August 2006, 01:16 AM   #5 (permalink)
Nocturnal,
V-bands can be found e.g. on HKS T51R Turbine (on the exhaust housing), it replaces nuts and bolts which are most commonly used.
For example To4R uses 4 bolts to connects/bolt on to the exhaust manifold, where T51R uses V-band, which consists of a circular clamp which clamps the circular connections (on the exhaust manifold and the turbine inlet to the turbo), a small bolt and nut to secure everthing. This set up INDEED make the job much easier (as stated previously)!
Not sure why they not use this fitting for exhaust system tho??!!
Hope it helps.
Regards
Skylinegtr0415
skylinegtr0415 is offline   Reply With Quote
Old 16th August 2006, 05:12 AM   #6 (permalink)
Asim R32GTR's Avatar
This is from a Norwegian webpage, but here you can se what a v-band clamp is...
http://www.vangbo.no/pdf/V-band_koblinger.pdf
Asim...
Old 16th August 2006, 08:17 AM   #7 (permalink)
R32 Combat's Avatar
The T51r has a V band on the manifold, wastegate, AND the exhaust.
No gaskets are needed, the hotter it gets, the more it seals. I can remove the turbo in 5 mins. It's a much better system and it allows the exhaust inlet to be a round hole so the flow is much better.
Old 16th August 2006, 11:04 AM   #8 (permalink)
Nocturnal's Avatar
Thanks guys, I know I can trust you guys when I have no idea what I am talking about.
Nice one T51R by the way....
