Old 17th August 2006, 08:09 AM   #1 (permalink)
Pikey's Avatar
OK - what else could I have broken?
Finished putting in the new gearbox and propshaft last night
However, as I drove it out of the workshop there is a clunk as you engage the clutch - sounds like its coming from the back of the car. Im pretty certain its nothing to do with mart's gearbox or jay's prop, or the clutch itself, so maybe the rear diff is broken?
I left it at the garage as a precaution, Steve will have a look again today. Im pretty gutted as I was hoping to drive it home but never mind
Old 17th August 2006, 11:31 AM   #2 (permalink)
lightspeed's Avatar
Rear diff could be missing a tooth or more - or more likely just killed the mounting bushes/bolts on the diff or subframe.
By the looks of the damage it seized the whole transmission until the prop shaft sheared off. That's a lot of shock loading to be dealing with.
Old 17th August 2006, 11:42 AM   #3 (permalink)
T.F.S.'s Avatar
TXB/diff
the calibra TXB makes a sound just as you describe when it dies but im sue the nissan version is much stronger? and less likely to fail like that
T.F.S. is offline   Reply With Quote
Old 17th August 2006, 12:26 PM   #4 (permalink)
Pikey's Avatar
What's a TXB?
Old 17th August 2006, 12:27 PM   #5 (permalink)
T.F.S.'s Avatar
oh lol
transfer box
Old 17th August 2006, 12:41 PM   #6 (permalink)
lightspeed's Avatar
I thought you put a replacement transfer box in???
Old 17th August 2006, 12:42 PM   #7 (permalink)
Pikey's Avatar
No, its definitely not the transfer box - that's new as is the gearbox - all came as one unit out of Martin's car, which I drove prior to purchasing
Old 17th August 2006, 12:57 PM   #8 (permalink)
The only transfer box related thing I can think of is that I think it was gear oil came out of my transfer box though which is what I put in my new one which again is fine. maybe its this as you put ATF fluid in your yours - mind you based on what has been said on here, it sounds like ATF is fine
Would it be the rear diff? As someone said, your gearbox was torn in half so that must have been some force on the rest of the attached parts.
Old 17th August 2006, 01:03 PM   #9 (permalink)
Pikey's Avatar
It does it if you load the car up on the handbrake - ie if you sit with the handbrake on and bring the clutch up to biting point quite quickly you get a clunk from the back.
We havent bled the 4WD system yet and Ive turned the system off (fuse out), so there's actually no way it could try and put power to the front at the moment anyway
Old 17th August 2006, 02:26 PM   #10 (permalink)
Driveshaft?
rear diff?
prop?
what else could it be? might be worth bleeding the 4wd system and running it normally. Whilst it may not be running in 4wd it may still have a connection to the front? might be worth doing just to eliminate it?
Old 18th August 2006, 10:29 AM   #11 (permalink)
Pikey's Avatar
Bit of further investigation last night, we think its broken the diff too
Moving one of the rear wheels round (with the car in the air), you can move the wheel round about half an inch, then the diff goes 'donk' then the other wheel + the prop start to move. Is this excessive?
Old 18th August 2006, 10:34 AM   #12 (permalink)
rb30 710bhp
rockabilly's Avatar
Send a message via Yahoo to rockabilly
diff pinion/planet cradle for deffo...sorry mate
fancy the south of france.
http://st-tropez.mysite.orange.co.uk/
Old 18th August 2006, 12:36 PM   #13 (permalink)
Pikey's Avatar
bugger
Old 19th August 2006, 12:55 PM   #14 (permalink)
Pikey's Avatar
Nope - it was the replacement propshaft that broke! The rear CV-joint-type-thing has broke
So I need another propshaft please anyone
(play in the diff sounds like it may be normal)
Old 22nd August 2006, 10:36 PM   #15 (permalink)
Elitetech Automotive
Ian C's Avatar
Good luck with the test drive Pikey.........Hope my spare bit puts the smile back on your face!
Ian
+10 extra bhp for £55....
Get your baffled TWIN TURBO pipe now from GTR.co.uk Shop
My project
Ian C is offline   Reply With Quote
