Could Apexi Induction cause this problem?
Since I fitted an Apexi Induction kit to our R34 GTT, it seems to... well, it don't feel right.
The only way I can describe it is that it feels like it's stuttering it's way up the revs when you boot it. The power comes and goes completely randomly. I've also noticed that take-off speed is suffering and I'm convinced that fuel economy has plumeted. So here's my theory based on some stuff i've read... the increased airflow provided by the Apexi is telling the ECU to over-fuel in order to compensate and not run lean. As a result, the car's choking on it's own fuel? Resulting in crappy economy, jerky performance? What do you think, could I be right? If so, can you suggest a cheap solution? I heard if I put some Iridium plugs in there that could help? Certainly can't afford any kind of ECU or power FC etc. and it would be a shame to get rid of the Apexi and go back to completely standard Any thoughts/comments would be greatly appreciated! ![]() |
ADMINISTRATOR
erm, this may not be the same problem, but i had new elbows and steel turbo's fitted yesterday, and the improved flow has caused a small misfire at low RPM.
the solution is a power FC, but in the meantime, disconnecting the lambda's has cured it fuel consumption might increase, but rich is better than lean maybe the same issue? mook
FOR ALL GTR FORUM RELATED ISSUES CONTACT THE ADMIN TEAM 'MOOKISTAR' OR 'MOLEMAN' SKYLINE FAQ'S! |
Location: somewhere over the rainbow ( not far from Jeff )
Had a GTT for nearly 2 years ,stage 1 mods ,whats your set up ,? just Airfilter ,have you standard exhaust,you running with a cat ,downpipes standard etc.If you have a problem and it is the filter it will be worse when it's colder .Always found slightly modded GTT's bit unpredictable ,set up needs to be spot on .Plugs, coils packs ,fuel filter ,2 stage boost problems ,is it mainly at about 5000 revs when you floor it?
Erm - I don't like the sound of that
Who's this a job for? Abbey? Stealth - exactly that mate, running everything completely standard bar the Apexi. The problems actually feel more like sub 5000 revs actually, the power seems to kick in properly about then. Thinking I may have to put the standard setup back in at this rate - it's not worth spending anything on when the Apexi only cost a few quid and doesn't have a positive effect anyway (without further mods). Last edited by Jono & Emma; 23rd August 2006 at 11:43 AM. |
Would something like this help me to diagnose the fault???
http://www.plmsdevelopments.com/consult_if.shtml |
#9 (permalink) | |
Jono/Emma
Sounds like a AFM fault or maybe a dodgy Lambda. Quote:
#10 (permalink) | |
ADMINISTRATOR
It' was running a 1 bar abbey setup, before i changed the turbo's and elbows for steel internals and HKS elbows. Thats what created the misfire, and although a powerFC is the ideal solution, disconnecting the lambda's has stopped the mis, he said it would run rich, but would be ok to drive to Germany next week! now you've got me worried.... mook
Cheers Abbey - next step was gonna be to give you guys a call actually so I'm glad you responded. This could well be the case, as the connector to the AFM was hastily wired together by me using some pretty shite materials. Think I'll take it somewhere to have that wired up properly and see if that makes a difference. Cheers everyone
#12 (permalink) | |
GTROC Board Member
Ditto what Mark says, but as Apexi's are a dry filter so AFM contamination couldn't be caused by filter. As for flow, the restriction is only slightly less the a std box and flow would be unchanged really, besides ecu should be able to compensate. Get it checked ASAP!
Regards, Scott. GTROC Members Secretary. Please feel free to PM me with any GTROC Membership or Merchandising issues. OO SKYLINE OO My R32's full restoration: http://www.gtr.co.uk/forum/upload/77...ht=restoration |
#13 (permalink) |
Massively late response but I'm posting the resolution in case anyone searches for this thread in future.
It was indeed my shoddy wiring of the plug to the AFM. I'd wired using bullet connectors (all I had when I was doing the job). On removing these it was clear that wires had come loose and were hardly making contact Oops!Anyway... got a mate to solder the connections instead so it's all hard wired now and is performing perfectly, as it should! Thanks to all for your hypothesiseses ![]() |
#14 (permalink) |
GTROC Board Member
Glad to hear its all sorted!
