Old 22nd August 2006, 06:44 PM   #1 (permalink)
carlreeve's Avatar
How many people run without a BOV or Recirc?
Any running issues, failures etc etc.
carlreeve is offline   Reply With Quote
Old 22nd August 2006, 07:10 PM   #2 (permalink)
skyline69_uk's Avatar
Only the mugs .
It's there for a reason, they appeared in the turbo racing world in the very early 70's to improve lap times and life of the turbos and there is no reason whatsoever to remove even today as they still do the same job. Some rally cars etc can do without them as can any car that has an open throttle shifter which isn't the GT-R.
This question is asked everywhere lol...
http://www.dsmtalk.com/forums/showthread.php?t=159821
スカイライン69 UK
Old 22nd August 2006, 07:12 PM   #3 (permalink)
R32 Combat's Avatar
Er, I don't use a BOV or re-circ. I use 2 overboost valves venting to atmosphere.
Old 22nd August 2006, 09:11 PM   #4 (permalink)
Purely noise suppresion reasons on 99% of standard cars fitted with em
IMO they not ANYWHERE near as vital as most people think.
But most people who know that still fit them in a "better safe than sorry" manor.
Can usually find a lot more people with proof its had no noticable effect than people who can prove running with one has helped them.
Lot of AFM equipped cars NEED them as airflow going backwards past the AFM messes the fueling up tho.
Performance reasons are generally laughable and despite a lot of searching, seems to have never been proven. Just tons of internet/book/tv rumour and myth, like "wastegate chatter" and other such bollocks.
Turbo reliablility reasons are genuine depending on boost level and turbo strength.
Some turbos are fine without one, I ran 30psi held boost for over 12k miles with no DV at all with no ill effects, hell, I ran agressive ALS at the same time just to make it worse, lol.
Did the same at 23psi on another car, and know countless people doing the same.
Theory has it that they do something, reality is what they do is far more often than not not even slightly noticable.
Old 22nd August 2006, 09:40 PM   #5 (permalink)
carlreeve's Avatar
The reason I ask is my car came with BOV's (not recirc ones) and all my recirc tubing has gone so no chance to retrofit to recirc.
BOV's mess up the AFM's but also leak and only hold boost to the spring rate of the BOV. Stronger springs can hold more boost but then BOV pressure release has increased also, same effect as not having a BOV at all?
Remove them and the leakage has gone, no more pressure relief but at a measily 1 bar does it really matter.
So do I invest in some new BOV's (as mine are past there best) or blank them off and run BOV-less.
Thats my choice but was wondering what the Skyline population has tried.
Old 22nd August 2006, 10:23 PM   #6 (permalink)
I doubt anyone in the UK skyline world has tried with none, its not the most daring scene ever!
I dunno how well the ceramic turbos will take it, but otherwise id have a go personally as never done me anything but good in the past.
But id never advise someone tho, as tried it on tons of cars, just never a GTR.
Old 22nd August 2006, 11:32 PM   #7 (permalink)
tyndago's Avatar
The Super Taikyu N1 race cars didn't have them. Not the 2 cars we have.
I am not that much of a fan of them. Most of my old experiences of them have been leaking under high boost. The leak does more damage by over spinning the turbo.
Old 22nd August 2006, 11:47 PM   #8 (permalink)
RoboPope's Avatar
it depends more on your ecu runs anything else, if you have a MAP sensor then who gives a shit but if you have metered air then you could over fuel and stall from time to time
RoboPope is offline   Reply With Quote
Old 23rd August 2006, 08:30 AM   #9 (permalink)
i've been "temporarily" running with blocked-off recircs for about a year now. had a bad one that wouldn't shut even at idle. figured blocking the outlet was a quick and easy fix till i got a replacement. haven't had any real problems.
pokey is offline   Reply With Quote
Old 23rd August 2006, 08:49 AM   #10 (permalink)
Careful mate, someone on the internet might call you a mug cause of stuff theyve heard but never tried
Glad someone else can back me up here, as id tried it many many maaaany times, but as ever on here, I expected the internet backlash, lol...
Old 23rd August 2006, 08:52 AM   #11 (permalink)
BoVs do not rely on the spring pressure to hold them shut against boost, they have boost pressure applied to the rear of the diaphram via the actuation pipe. The spring is only there to define the opening point in relation to manifold vacuum and to hold them shut during spool when there is a delay between pressure on either side of diaphram......
Old 23rd August 2006, 09:36 AM   #12 (permalink)
Philip's Avatar
My car didn't have one over the past year, for what it's worth.
Phil
Philip is offline   Reply With Quote
Old 23rd August 2006, 09:54 AM   #13 (permalink)
I'm only going by what half a dozen professional auto engineering books and a friend who spent 3 months with the Renault F1 team say but maybe they're all mistaken.
I know none of this from experience unfortunately just from what the text books and auto engineers say (I was going to be one but ended in computers instead (I'm the mug this time) and work with several people who did it at Uni etc).
I'm sure there are many situations when they are not needed or indeed cause more issues than they fix but I have never seen an AE textbook that ever stated those conditions - only pictures of the damage caused due to the lack of them Steve. The problem is surge causes other failures to happen first that mask the real cause and it appears like something else e.g. inbalance is the cause etc when the surge caused the metal on metal contact over time that in turn caused the inbalance. Only a professional test environment shows the real cause and AEs will look to see what caused the inbalance while everyone else just put it done to "wear" or a "dodgy turbo".
スカイライン69 UK
Old 23rd August 2006, 10:02 AM   #14 (permalink)
Indeed - you will not achieve 160 000km durability without a dump valve. Does this concern the average GTR owner / tuner, probably not. It does not change the reason for the component being used!
Old 23rd August 2006, 10:07 AM   #15 (permalink)
Yeah, cause TURBOS are such a top subject on a modern F1 car
And for what its worth, when F1 cars were turbod in the 80s, did they run dumpvalves? Not on any ive seen, and I know someone who builds historic turbo F1 engines for a living...
Neither do any LeMans/GT cars ive seen actually...
Must be mugs
