The cheapest and safest way to boost up your car is to add a boost controller and a piggy back ecu upgrade. I use the Blitz SBC-iD boost controller and try a GReddy E-manage. They are pretty easy to work with. but dont go much past 1.2 bar or so. The stockers can and I have done it but dont recommend it. I have put out 1.32 before but only for a second until I realized what I did. Then I turned it down. It is real easy to get excited and overboost.
Chris ![]() Last edited by R-33VSpec karma; 29th November 2002 at 03:36 AM. |
#7 (permalink) | |
Marv,
Make sure before you up anything, that the info you are working from is relevant to your car ![]() The GTS-t stock turbo will fail rather quickly with anything more than about .9bar boost. Fueling will be the limiting factor beyond this anyhow, so play safe. Quote:
The cheapest way to up the boost, is using a bleed valve. Either way is easy, but you will need a reasonably accurate Boost Gauge before attempting to do it with a bleed valve. R33Vspec Karma, That's pretty duff advice you've given above, Marv asked specifically about the GTS-t, and there is nothing cheap about the Greddy E-Manage when you need a laptop to program it.
Expired.... [E&OE.....] |
My bad, I assumed he had an R and didnt read the rest of the thread, just the main question, I am sorry about that guys. I paid 35000 yen for my e- manage and 5000 yen for my support tool. That works out to about $400 US and thats not too bad compared to Power FC and is nothing compared to an F-Con. But yes, they do require a laptop and I failed to mention that. I am sorry for the miss information guys.
Chris |
