Old 1st September 2006, 11:49 AM   #1 (permalink)
Pikey's Avatar
4WD connected to ABS - why?
Whenever you get the 4WD light on, the ABS light always comes on with it! Why is this?
I understand why pulling the fuse turns them both on - cos they're on the same fuse - but when you've got a fault with the 4WD system (G-sensors) like I have, why doesnt the ABS work? Seems very strange that two systems that shouldnt really be connected with one another should be knocked out together when there's a fault with one of them!
Old 1st September 2006, 11:53 AM   #2 (permalink)
Toby Broom's Avatar
Send a message via MSN to Toby Broom
doesn't the 4wd use the same wheel sensors to detect if the rears have lost grip an transfer power to front?
Toby Broom is offline   Reply With Quote
Old 1st September 2006, 12:07 PM   #3 (permalink)
Pikey's Avatar
That's part of it, yeah. But I dont have anything wrong with my ABS sensors, only the G-sensor unit which is nothing to do with the ABS system !
Old 1st September 2006, 12:39 PM   #4 (permalink)
R32 ATTESA computer also controls the ABS. For safety sake if a vital 4WD component fails the ECU will turn everything off.
Some smart ABS systems use 'G Sensors' to detect acceleration. This helps in the situation where you lock up every wheel, thus fooling the ECU into thinking the car is stationary (as the wheel speed is 0). If the ABS system references an accelerometer the rare situation where the ABS doesn't work under a full lock up is avoided.
However from memory the R32 ATTESA ECU doesn't use the G sensor for ABS operations.
Having said that I'm sure I've had my G sensors disconnected and the ABS light didn't come on...I may be suffering from clouded vision though :P
Zoltarc is offline   Reply With Quote
Old 1st September 2006, 02:57 PM   #5 (permalink)
Toby Broom's Avatar
I think they though that 20yrs down the line, there'd be some guy with a G sensor problem and they dissable everything to **** him off.
Old 1st September 2006, 04:10 PM   #6 (permalink)
Pikey's Avatar
I think that too
Old 1st September 2006, 05:51 PM   #7 (permalink)
Rich C's Avatar
Atessa
The "ABS sensors" are actually wheel speed sensors, Atessa compares the individual wheel speed with the G sensors to work out if the car has lost grip and applies the neccessary power to correct the slide.
The GTR was one of the first cars in the world (maybe the) to apply this type of system and the two systems are directly linked, that's why pulling one fuse disables both systems.
An amazing system when you consider it was developed almost 20 yeas ago now! In my opinion modern traction control works in the completely wrong way - basically the same way but in reverse by removing excess power through ABS.
I think the R34 V-Spec II's may use both methods?
Rich C is offline   Reply With Quote
Old 1st September 2006, 05:55 PM   #8 (permalink)
Rich C's Avatar
Do you know it is definetely the G-sensors? HAve you checked with Consult / Diagnostics.
BTW I know the person that developed the G-sensor for the original GTR, i'll ask him why they did it like that..
Old 2nd September 2006, 12:29 PM   #9 (permalink)
Pikey's Avatar
Yeah definitely G-sensor. Ecu flashing codes 12 and 13, and the indicator on the front of the sensor unit has turned red
